james0202 0 Report post Posted November 6, 2009 Apparently there is a 'new regulation' for WOF and one of them is that you cant ignore the warning messages in the OBC. The right side did not have any power for brake lights so I cut that off and hooked it up to the left. The problem is solved but now the other problem is that OBC will throw messages at me forever. This dumb mechanic thinks chucking the factory ones will fix the problem but I know that is not the case. Is there a way to unhook the OBC (just the OBC not the clock) temporarily? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted November 7, 2009 (edited) Apparently there is a 'new regulation' for WOF and one of them is that you cant ignore the warning messages in the OBC. The right side did not have any power for brake lights so I cut that off and hooked it up to the left. The problem is solved but now the other problem is that OBC will throw messages at me forever. This dumb mechanic thinks chucking the factory ones will fix the problem but I know that is not the case. Is there a way to unhook the OBC (just the OBC not the clock) temporarily? Why don't you fix the fault instead of trying to hide the warning messages? "The problem is solved" No it is not. it is simply masked, but not solved. Imagine on a Jumbo Jet: "Captain, the Number 1 is on fire" "That's OK CoPilot, just take the bulb out of the warning light" Edited November 7, 2009 by jochen Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted November 7, 2009 Why don't you fix the fault instead of trying to hide the warning messages? "The problem is solved" No it is not. it is simply masked, but not solved. Imagine on a Jumbo Jet: "Captain, the Number 1 is on fire" "That's OK CoPilot, just take the bulb out of the warning light" hehehe sort of reminds me of a Simpson episode where they are driving along and lisa say's dad whys the engine light on and he replys cause the tapes fallen off doh Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted November 9, 2009 Apparently there is a 'new regulation' for WOF and one of them is that you cant ignore the warning messages in the OBC. The right side did not have any power for brake lights so I cut that off and hooked it up to the left. The problem is solved but now the other problem is that OBC will throw messages at me forever. This dumb mechanic thinks chucking the factory ones will fix the problem but I know that is not the case. Is there a way to unhook the OBC (just the OBC not the clock) temporarily? Pull the plug out the back of it Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 11, 2009 I don't really understand safety related warning features in my car so I'd suggest "Pull the plug out the back of it" Fixed Quote Share this post Link to post Share on other sites
