325GRANT 0 Report post Posted January 12, 2005 anyone know of a 2.7 eta head for sale??? poss swap for 325 head??? Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted January 12, 2005 give me a call . 021433600 or email me . [email protected] Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted January 13, 2005 There is a 525ee at Turners in Auckland, damaged front and rear. If you buy for the head, I would like the short block... Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted January 13, 2005 i've got a block, crank, con rods etc in FS section....that is most likely going to be For Sale soon Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted January 13, 2005 anyone know of a 2.7 eta head for sale??? poss swap for 325 head??? i have a access to a m20 2L head which is sitting on a 525e block at the moment . the guy will sell seperately Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted January 14, 2005 before i go to much further with this can anyone tell me if a 2.7 head will give me lower compression on a 325 block? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted January 14, 2005 if your using 325i pistons dont use an 'e' head....they arent matched..not sure bout compression off the top of head Quote Share this post Link to post Share on other sites
petone 0 Report post Posted January 14, 2005 I'm not sure on this but i thought the 2.5 head was better than the 2.7 and when the 2.5 head is on the 2.7 block it gave you lower compression anyway? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted January 14, 2005 ill scan and post up the article in TBMW about 2.7 builds...clears up a lot of confusion....sometime this weekend Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted January 14, 2005 that would be helpful thanks Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted January 14, 2005 that would be helpful thanks you want a 2.7 block (longer stroke) .2.5 pistons (matches head shape)and a 2.5 head(bigger valves) 2.5 ecu ,manifold etc to get more power ..you might have to machine groves in pistons for valve clearances (depending on which pistons the 2.5 had) Quote Share this post Link to post Share on other sites
