just-drift-it 0 Report post Posted November 16, 2009 (edited) Im after a brake booster for a 1986 e30 Cheers. Edited November 17, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
rds 0 Report post Posted November 16, 2009 I have one in chch, PM if interested Quote Share this post Link to post Share on other sites
just-drift-it 0 Report post Posted November 16, 2009 Im in Auckland how much do you think it would be to send up here? Also are they very hard to replace is there much involved? Cheers. Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted November 16, 2009 Ive got one too if your interested Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted November 16, 2009 $20 on the North Shore 0212435526 Quote Share this post Link to post Share on other sites
rds 0 Report post Posted November 16, 2009 Im in Auckland how much do you think it would be to send up here? Also are they very hard to replace is there much involved? Cheers. Does it need to be replaced? No its pretty easy, unhook and unbolt from behind the glovebox and remove the master cylnder from the engine bay side. About 6 nuts and 1 clip from memory Quote Share this post Link to post Share on other sites
just-drift-it 0 Report post Posted November 17, 2009 Does it need to be replaced? No its pretty easy, unhook and unbolt from behind the glovebox and remove the master cylnder from the engine bay side. About 6 nuts and 1 clip from memory Ok thanks, do i need to bleed the brakes or anything after i have replaced it?Cheers. Quote Share this post Link to post Share on other sites
rds 0 Report post Posted November 17, 2009 Ok thanks, do i need to bleed the brakes or anything after i have replaced it? Cheers. No you shouldnt have to Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 17, 2009 Yes ...you will have to bleed the brakes as the master cylinder needs to come off the booster to get the booster out Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted November 17, 2009 I didn't need to bleed the brakes when swapping the booster, all you have to do is unbolt the master cylinder, slide it out, unbolt the booster and slide it out, then put the in replacement. Having said that it, it takes some convincing to get the booster in and out as there is a limitation on space to move it in and out. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 17, 2009 Having said that it, it takes some convincing to get the booster in and out as there is a limitation on space to move it in and out. Thats because the master cylinder is in the way... how hard is it to bleed brakes ? 10 minutes work and no risk of damaging anything Quote Share this post Link to post Share on other sites
