keen 6 Report post Posted December 2, 2009 Can someone here help?I've got a motorsport 535 1989.It has memory seats and they intermittently keep adjusting themselves. This can be quite annoying when driving along and the seat adjusts fully forward or moves to a very uncomfortable position.While sitting in the car at the supermarket with the car not running or turned to auxiliary it just decided to adjust itself again just the drivers seat not the passengers.Any ideas? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 2, 2009 Is the side panel that houses the switch on the seat secure? If not - the switch assy may have detached & internal be causing a problem Quote Share this post Link to post Share on other sites
keen 6 Report post Posted December 3, 2009 Have checked to see if panel is loose but no its all neatly fitting and tight any other suggestions Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted December 3, 2009 sounds like a loose earth or connection prob , you might have to pull apart to inspect it?? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 3, 2009 Have checked to see if panel is loose but no its all neatly fitting and tight any other suggestions As above - need to remove & inspect the switch assy. I doubt it being a bad earth though. Is it only one direction that it moves itself? - Foward? No other eg back, up, or down? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 3, 2009 Can someone here help?I've got a motorsport 535 1989.It has memory seats and they intermittently keep adjusting themselves. This can be quite annoying when driving along and the seat adjusts fully forward or moves to a very uncomfortable position.While sitting in the car at the supermarket with the car not running or turned to auxiliary it just decided to adjust itself again just the drivers seat not the passengers.Any ideas?you sure they memory???if memory do the mirrors adjust too??? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted December 3, 2009 also the switches fail . get all gummed up and burned etc inside. Quote Share this post Link to post Share on other sites
Sick Puppy 1 Report post Posted December 4, 2009 also the switches fail . get all gummed up and burned etc inside.Just curious, but what is the resolution? Open up and clean out, or replace? Quote Share this post Link to post Share on other sites
keen 6 Report post Posted December 4, 2009 no the mirror does not change and the seats mainly move forward but it has moved up and back.But why does it move with the key off there have been flat batt problems in the past and now it appears that this may be the culprit Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted December 5, 2009 Could probably be quite dangerous, if it was me I'd have the bloody thing unplugged until it was sorted. No power = no accident. Quote Share this post Link to post Share on other sites
keen 6 Report post Posted December 6, 2009 That looks like the temp option Quote Share this post Link to post Share on other sites
