jas81172 0 Report post Posted December 27, 2009 hi, i'm just a new member here and about a year owner of a 320i e30 1988 BMW. i don't have enough knowledge on BMW so, i would just like to know what would be the oil grade that i should use for the differential oil. i'm planning to drain and refill the diff oil and how much should i put in. tks. Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted December 27, 2009 90w (or 75w-90, 80w-90). Make sure the car is level and fill until it starts to run out the top hole. About 0.9 to 1 litre probably. If you have an LSD you must used a LSD gear oil. Also make sure you undo the top fill hole first - if you undo the drain hole and then can't get the fill hole undone you are screwed. Quote Share this post Link to post Share on other sites
jas81172 0 Report post Posted December 27, 2009 90w (or 75w-90, 80w-90). Make sure the car is level and fill until it starts to run out the top hole. About 0.9 to 1 litre probably. If you have an LSD you must used a LSD gear oil. Also make sure you undo the top fill hole first - if you undo the drain hole and then can't get the fill hole undone you are screwed. how do i know if it needs LSD? do you suggest that i should undo the top fill hole first before i drain it to make sure? if i can't is there any alternative? tks. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 27, 2009 how do i know if it needs LSD? do you suggest that i should undo the top fill hole first before i drain it to make sure? if i can't is there any alternative? tks. unless the car has been modified at all then it wont be LSD. you cant confirm this though by jacking up the rear end, let the the hand brake off and put it in neutral, and spin one wheel. look at the wheel on the other side if it spins the same way its an LSD if it spins the opposite way its a standard open diff Quote Share this post Link to post Share on other sites
jas81172 0 Report post Posted December 27, 2009 unless the car has been modified at all then it wont be LSD. you cant confirm this though by jacking up the rear end, let the the hand brake off and put it in neutral, and spin one wheel. look at the wheel on the other side if it spins the same way its an LSD if it spins the opposite way its a standard open diff hi drew, if i remember it correctly when i had it safety checked the rear wheels turned the opposite direction when they checked it. so, it's a standard open diff. so i can use a 75w-90? tks mate. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 28, 2009 You should use a 75w90 full synthetic oil Quote Share this post Link to post Share on other sites
jas81172 0 Report post Posted December 28, 2009 You should use a 75w90 full synthetic oil i was thinking of 80w90 but if 75w90 is best then i'll go for it.thank you very much for the replies. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 28, 2009 hi drew, if i remember it correctly when i had it safety checked the rear wheels turned the opposite direction when they checked it. so, it's a standard open diff. so i can use a 75w-90? tks mate. *Andy. yeah thought as much i was thinking of 80w90 but if 75w90 is best then i'll go for it.thank you very much for the replies. probably minimal difference between the two? Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted December 28, 2009 Unless you have a rotary synthetic is almost always best. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted December 28, 2009 Redline 75w90. Can get it from BNT. Quote Share this post Link to post Share on other sites
