2002 1 Report post Posted December 30, 2009 (edited) So, I had the throttle body off the 2002, which is kind of tricky as I use an E30 318 manifold with a 325 throttle body and dropped one the the nuts the hold it on. Not surprising you're working blind on the tips of your fingers. After looking for it for about 15 minutes I gave up and assumed it was either hung up in the chassis or I'd kicked it across the garage under the other 2002. Wrong! It was hiding in the air cleaner, so I go for a drive around the block - All good and set up to check the timing, I was just getting a spanner to tweak the dizzy and the mother of all banging noises starts. The picture shows where I found the nut.! Edited December 30, 2009 by 2002 Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 30, 2009 Ugh, Pulverised. Is the damage repairable? Bad luck dude Quote Share this post Link to post Share on other sites
2002 1 Report post Posted December 30, 2009 Ugh, Pulverised. Is the damage repairable? Bad luck dude I believe so, I've gound away the damaged area on the head. Surprisingly little material had to be removed. The piston looks fine and the top ring rotates freely. (Score 1 to a JE forged piston). I've bent the intake valve so I'll replace that and it's rocker plus the head gasket etc. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted December 30, 2009 (edited) you didn't come out to bad and good to hear the pistons alright, wish i could say the same to my engine that dropped a valve Edited December 30, 2009 by Jamez Quote Share this post Link to post Share on other sites
2002 1 Report post Posted December 30, 2009 you didn't come out to bad and good to hear the pistons alright, wish i could say the same to my engine that dropped a valve Now that really sucks! Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted December 30, 2009 (edited) I love my telescoptic magnet for this reason It has rescued a bolt from down a spark plug hole in a mates car ( thankfully we knew about it ) Dad as a story about my sister dropping a bolt down the guts of a Rover v8 when she was 3- he had to pull apart quite a lot to get to it. Good luck reparing the damage, but my question is .. If material was removed how much will this change the compression ratio ? While the head is off would it not be a good idea to have it re surfaced anyway, forged pistons suggest a serious engine where the effort might count for something .. Edited December 30, 2009 by Jimmy Quote Share this post Link to post Share on other sites
2002 1 Report post Posted December 30, 2009 If material was removed how much will this change the compression ratio ? Not signficantly, the volume of the combustion chamber is around 55cc (estimated from cylinder volume and compression ratio). So if I removed a whole cc of material the compression ratio would go from 10 to 9.93. I haven't measured how much material I removed yet, but it could only be a small fraction of a cc. Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted December 31, 2009 worst thing ive done is left the power bar on the crank pulley then went to start the car made a good dent in the floor funniest thing ive seen someone do is install a new intercooler on their skyline a week later they were complaining of a lack of power so we pulled it out and found the rags used to stop nuts getting in it were still there blocking off half the cores Quote Share this post Link to post Share on other sites
mynbmr 225 Report post Posted January 8, 2010 So, I had the throttle body off the 2002, which is kind of tricky as I use an E30 318 manifold with a 325 throttle body and dropped one the the nuts the hold it on. I just bought one of these, only 12.00 with light Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted January 10, 2010 That's sweet. Where'd you get it? Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted January 10, 2010 group buy? Quote Share this post Link to post Share on other sites
