antil33t
Differences between E30's with AC, and without.
You're welcome. <_<
Thanks John & Co. :P
Me love you long time.
Edited by antil33t
Um no. There is a second piece which only is needed for PS and A/C belts.
If you have ever taken the front of an m20 apart you would know this. And the Alternator/ waterpump belt runs right off the crank wheel. Sorry bud.
i have changed a water pump and all the belts before, didnt know the crank came apart though!
There is the front crank wheel. This runs the alternator belt. There is another 2 infront of it, but that part is separate, which runs the other belts. You can take it off.
Many times I have put the crank wheel back on without that front bit, which meant taking 6 bolts out and putting that other bit on again. Fuuuu.
No worries.
Best wishes from John and the team.
lmao
Power to Weight, it all adds up :D
my mate removed all the aircon from his early 80's Corona ... the aircon radiator is the same size as the normal radiator !!
heavy son of a b***h too
