flake 0 Report post Posted January 17, 2010 started piecing the engine back together last night, hoses wires etc. and notice two hoses didn't go anywhere as if something was missing. posted a picture, looks like number 11 is missing on my engine. what is this part called? any help thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 17, 2010 (edited) Air temperature operated thermostat that opens to allows hot water to go to the throttle body to stop icing up. It fits into the airfilter air box Edited January 17, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 17, 2010 Free bump if anyone sees this and has one, we need one asap to get his m50 up and running. Pm me if you have one. Cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 17, 2010 Free bump if anyone sees this and has one, we need one asap to get his m50 up and running. Pm me if you have one. Cheers Just join the 2 hoses temporarily or blank them off...its not going to worry it Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 17, 2010 Your a legend Glenn Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted January 17, 2010 M20's have the same setup... I thaught it was odd having water pipes attached to your t-body at first Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 17, 2010 Join the hose from the head straight to the throttlebody. You can cut and maneuver the hose (#14) to fit where #15 would go on the throttlebody. Then ditch hose 15. Quote Share this post Link to post Share on other sites
mark247 41 Report post Posted January 17, 2010 If your car isn't going to be sitting in minus zero temperatures, you dont need it. I've never hooked mine up. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted January 17, 2010 according to this internets it's "tuning" to remove them on an M20. Be nice if he told you what removing them would acheive. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 17, 2010 M20's don't have a thermostat on them though, And it's easily bypassed using the stock hoses. It's harder on the m50 because you would have to twist around the big 'T' hose that splits to the throttle body, expansion bottle, firewall etc, you would need to join it to the cooling rail thing on the m50. I don't think you can really do it that way though. It's no biggie anyhow. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 17, 2010 Cheers for the help everyone Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted January 17, 2010 Just join the 2 hoses temporarily or blank them off...its not going to worry it This. Extremely common to do this on E30M50 swaps Quote Share this post Link to post Share on other sites
flake 0 Report post Posted January 18, 2010 thanks guys, guess i'll be bypassing the valve then Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted January 18, 2010 I welded up the barbed fitting that goes in the head, and used the spider hose from an m20 (hose #6 in that diagram), since it dosent have the little hose coming off it. Quote Share this post Link to post Share on other sites
