e30ftw 432 Report post Posted January 19, 2010 My left rear door is stuck closed for some stupid reason. It was off and put back on. Door is straight. Wont open from inside or outside latch. It's as if kiddy lock is on? But the outside won't open it. Can't pull it. Release latch somewhere inside?? Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted January 19, 2010 sounds like u need to re adjust your central locking solenoid, try winding down window, use key on outside and open with the inside handle at same time. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 19, 2010 sounds like u need to re adjust your central locking solenoid, try winding down window, use key on outside and open with the inside handle at same time. Its a 4 door Mike Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 19, 2010 (edited) Release latch somewhere inside?? Unfortunately .... no... and kiddy locks only work on the inside handle... you should know that Edited January 19, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted January 19, 2010 Ive had it happen in the past, generally when the batterys been disconnected and the driver door has been locked when this has been done. using key will seem like its stiff and wont open but sometimes if you use the inner door handle and turn the key at same time it will open. or... maby i just drink too much haha. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted January 19, 2010 (edited) The doors haven't had power to them in a long long time. I must have mis-aligned the locking latch I guess. Yeah I know the kiddy lock only does the inside door... But I said it's 'as if' kiddy lock is on. The inside handle acts as if the door is locked and I can't pull on it at all if the door lock is down. If the door lock is up it comes out abit but acts as if the door is locked. The outside handle comes out as normal, But doesn't release the door.' Time to weld / shave the rear doors? Edited January 19, 2010 by e30ftw Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted January 19, 2010 The pin from the centeral locking? Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted January 19, 2010 The pin from the centeral locking? the one you press down to lock door, im guessing your door cards still on? Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted January 19, 2010 Nope its all stripped. Can't see or feel crap, I've pulled the cover so I can see in the door etc. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted January 19, 2010 Nope its all stripped. Can't see or feel crap, I've pulled the cover so I can see in the door etc.ok sweet that makes things easier try loosining the two screws that hold the central locking motor in place Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted January 19, 2010 (edited) I was tryna find where it is lol, and in the process I pushed the door abit and the door pushed off the lock and opened abit without even touching the handle. Then i got it open from the outside cos it had caught into the latch I guess. Going to re-align the door and lock now, it seems to be way off lol.. whoops. Edited January 19, 2010 by e30ftw Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted January 19, 2010 No Glenn. The door is fitted fine. The latch must be a pin d*ck out of line because the lock meets with it correctly, but when it closes it won't open without some force and not using the door handle. I mean, unless I am missing the 'door lock' alignment tool, I guess it's abit of a trial / error thing lining it up. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted January 24, 2010 I've deleted 10 posts. Stop being a bunch of immature assholes. If you are not able to help John, then keep your mouths shut. I'm particularly disappointed about those that are supposedly older and wiser, and should know better (Glenn, Will). And James, who asked you? Keep this crap out of the forum. Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted January 24, 2010 (edited) Well done Graham, It seems to me both Andrew & John have been singled out for "special treatment" & its time some of you just buttoned up & let them run their threads-its getting f**king boring!!! Sure they might sometimes be a bit brash & cocky but who wasnt at their age. They should be getting credit for having the balls to even take on these projects not getting flamed every time they open a thread. How did you guys learn your skills?-no doubt from having a go & making plenty of cock ups & I bet you didnt have a bunch of smartarses flaming you at every turn. And that is my 2c. Edited December 3, 2021 by E30 325i Rag-Top Quote Share this post Link to post Share on other sites
