Wom 0 Report post Posted January 20, 2010 (edited) Hi Last night while driving around I heard a slight noise coming from what I believe to the be the front left side of the car. It sounds very similar to a stone stuck in the brakes, but there is no noise when braking. The noise only happens when I go over little bumps in the road, like man-hole covers for example. Before I start pulling my car apart and checking that everything is nice and tight and where it should be, is there anywhere specifically I should be looking? 1996 E36 323i Coupe with motorsport options Cheers Edited January 26, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 20, 2010 Jack that side up and turn the wheel by hand. If the noise is there it can only be brakes or a stone caught in there somewhere. Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 20, 2010 cheers, will give that a go first tonight and post up results Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 26, 2010 hey Sorry I haven't got around to jacking the car up and checking the wheels yet. I'm hoping that it wont be raining tonight so I can give it a go (no fun doing it in the wet, and don't have a garage). anyway, I think I have another issue now I've noticed in the last couple of days that it's taking quite a lot of turn on the steering wheel before the wheels start responding very noticable at slow speeds (anything less than 30kph), like backing out of the driveway for example I'm having to turn the wheel further around than normal just to get small corrections in the wheels while moving slowly on the motorway it's hardly noticable at all happens while reversing and driving forwards could the noise and the steering possibly be related? I'm guessing that question is like asking how long a piece of string is I'm thinking this might be best to get checked out by a pro, but am curious as to what kind of repairs / repair bill I may be in for, or if there may be something I could check out before taking it to a mechanic? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 26, 2010 Hi Last night while driving around I heard a slight noise coming from what I believe to the be the front left side of the car. It sounds very similar to a stone stuck in the brakes, but there is no noise when braking. The noise only happens when I go over little bumps in the road, like man-hole covers for example. Before I start pulling my car apart and checking that everything is nice and tight and where it should be, is there anywhere specifically I should be looking? 1996 E36 323i Coupe with motorsport options Cheers might be your anti rattle clip on your caliper has gone missing?. the steering could be a worn rackend or at worst the rack its self?, these are the common faults i seem to come across alot. best to get it to a hoist and have a look. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 26, 2010 Doesn't sound good or safe, suggest you rip the wheel off soon as possible and check for any loose suspension/steering parts. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2010 (edited) Check your power steering oil level.. I think you may have leak. The noise is caused by fluid/air cavitation Edited January 26, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted January 26, 2010 The noise is caused by fluid/air cavitationYou need a medal for your diagnostic genius-ness Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 26, 2010 ok, checked the power steering reservoir, plenty of fluid in there I wiped the dipstick on a rag and it is nice and red but when I looked down into the reservoir it didn't look that red anyway, I jacked up the car to have a look underneath damn it's oily under there and there's a couple of spots on the driveway that look dirty red took some photos (I can post hi-res if required) ... I noticed this piece in particular looks like it has snapped off from where it is supposed to be oh and also, I spun the wheels, just the slight noise from what I'm presuming is the friction of the brake pad but I did notice that the bump stop is sitting at the bottom (this is the left wheel) is it supposed to be there, because on the right wheel it stayed up when I jacked the car up also the orange rubber part appeared to be broken cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2010 Buggar.. If I could check the car and drive it to hear the noise that concerns you, I'd be in a better position to help.. will recheck your posts and try and evaluate something from this in the morning... got freinds coming soon Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted January 26, 2010 Definitely looks like red fluid has been leaking around in there... Why not give that whole area a nice degrease and could clean up then see if it's still leaking or been like that for quite some time? Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 26, 2010 yep gonna degrease it shortly and take it for a drive cheers for the help so far everyone if there's any more pics I could take or any further info I could provide, let me know ... actually, I might try getting a sound clip of the noise it makes have to wait until late though, traffic noise tends to drown it out Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 26, 2010 yep gonna degrease it shortly and take it for a drive cheers for the help so far everyone if there's any more pics I could take or any further info I could provide, let me know ... actually, I might try getting a sound clip of the noise it makes have to wait until late though, traffic noise tends to drown it out can you take a pick of caliper and disk etc. Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted January 26, 2010 dayum.. thats dirty.. and i thought my one was oily dirty before hahaha Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 26, 2010 (edited) lol yea used up a whole can of degreaser on it last night and still didn't get it as clean as I would like it if it helps with diagnosis, I was doing a wee bit of off-roading on Saturday, only briefly (less than 1km) but it was gravel and quite bumpy just thinking that it may possibly have made something fall out of place Kerry - will take a picture tonight when I get home [edit] mods - could you maybe update my thread title to Strange Noise + Steering Issue Edited January 26, 2010 by Wom Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 26, 2010 Don't worry about your bump stops, you should be able to move them up and down anyways, if they get a bit of use then they eventually deteriorate. Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 26, 2010 ok cheers Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 28, 2010 quick update, gave the mechanical warranty company a call to discuss and they said to take it into the mechanic to get fixed, so looks like it's covered under warranty (boy has that saved me a bit of coin) rung the mechanic, all booked in for Monday morning he thinks from what I told him on the phone that maybe something has broken, possibly a universal joint, but he can't really pinpoint what's wrong without hoisting the car up and having a look around thanks for your time and help everyone, it is very much appreciated I'll post up the results once I get it back from the mechanic Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 31, 2010 the mechanic has had a look at it today he said that the left ball joint is pretty stuffed and he'll replace that couldn't find anything else wrong, so he's pretty sure that replacing the ball joint and getting a wheel allignment will fix it all up he also said that when taking it for a road test that he didn't notice anything wrong with the steering ... which is something I also noticed .... that it is only noticable at very low speeds (less than 15kph) unfortunately wont be able to pick it up until wednesday as they're quite busy at the moment Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted February 3, 2010 left side ball joints replaced, wheel alignment done steers good now Quote Share this post Link to post Share on other sites
