bali_nz 0 Report post Posted February 13, 2010 (edited) My car decided to transfer it's trans fluid into the radiator, it chose to do it up the coromandel,4 hours from home, just to make my life more interesting. I understand the pipe holding the trans fluid in the rad is no longer intact, and a new radiator is neccessary. What I need to know is, will this be the end of the prob. Have been told that it is more than likely that the trans was probably the source of the prob, and that some part of it is likely at fault, causing too much pressure through the cooling system. I've got no problem putting in a new radiator, but a new trans, and radiator on a 21 year old car is getting very close to no longer viable. Any advice would be appreciated. Edited February 13, 2010 by bali_nz Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted February 13, 2010 (edited) You might want to resize your pic to 800x600 or smaller or else one of the mods will delete it Your best bet is probably to get a second hand radiator from someone like Ray @ hellbm. Edited February 13, 2010 by Jamez Quote Share this post Link to post Share on other sites
bali_nz 0 Report post Posted February 13, 2010 You might want to resize your pic to 800x600 or smaller or else one of the mods will delete it Your best bet is probably to get a second hand radiator from someone like Ray @ hellbm. Pic resized, cheers Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 13, 2010 Pic resized, cheers i would also be very keen to ascertain that the radiator hasnt transferred it s fluid to the trans....NICE looking car mate. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted February 13, 2010 You could do a manual swap... it's just an M20 after all <.< Quote Share this post Link to post Share on other sites
bali_nz 0 Report post Posted February 13, 2010 i would also be very keen to ascertain that the radiator hasnt transferred it s fluid to the trans....NICE looking car mate.Looks as if a little coolant got in the trans, probably even a lot seeing as it's just sitting there now.Will a decent flush sort this, bought plenty of ATF when considering limping it home, before finding that the fluid was in the radiator. Quote Share this post Link to post Share on other sites
bali_nz 0 Report post Posted February 19, 2010 Another query? If I get the work done, how's the cooling system ie water pump etc, gonna like the fact that it's had trans fluid running through it. Am I gonna have to replace any of that, or take any particular precautions? Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted February 19, 2010 water/coolant will stuff a trans in a very short time ,it disolves the glue that holds the clutch friction matterial on to the clutch plates. trans oil in the coolant system wont matter . Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 19, 2010 trans oil in the coolant system wont matter . Yes It will Brent.. it will perish the hoses, water pump seal and header tank seals on the radiator & heater matrix. We have a special flushing fluid for getting it out. I have the info at work & the name of the supplier. We use it all the time on Audi's when the engine oil coolers crap out. Quote Share this post Link to post Share on other sites
