Venatus 2 Report post Posted February 26, 2010 Ok, anyone know of a good way to get stripped bolts out? 5 of 6 bonneT mount bolts snapped off in the holes. I drilled em and got a screw extractor, but that snapped off in it as well so I'm guessing I'll have to take it to an engineer? also, I think it must be the fuel pump relay is buggered, whenever you switch on the headlights with the engine off you can hear the relay buzz and the pump try and re pressurise the system for a second. I'm Hoping It's just the relay anyway Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted February 26, 2010 Dont worry about it and bolt it on with the 5 you have. its only a bonnet Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted February 26, 2010 Dont worry about it and bolt it on with the 5 you have. its only a bonnet WTF He stripped 5 out of 6. Meaning on 1 is able to be used. Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted February 26, 2010 Yeah and now one of them has a tungsten chrome alloy rod stuck in the middle of it. My drill bits basically just shine that thing up Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted February 26, 2010 Fuel pump relay should not be priming the system when you turn the head lights on. Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted February 26, 2010 How did you manage to snap 5 bonnet bolts? Just get a 2nd hand bonnet dude. Easy fix. Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted February 26, 2010 Fuel pump relay should not be priming the system when you turn the head lights on. No it shouldnt, which is why I am asking. Its pretty noisy, was wondering if its the relay itself that is the problem, or something else likely? Hmmm the bonnet paint is in really good condition, its just the threads were a tad rusty from not having been attached in 6 years. Im wondering if its cheaper to get another bonnet or get an engineer to remove said snapped bolts. Any ideas on prices? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted February 26, 2010 WTF He stripped 5 out of 6. Meaning on 1 is able to be used. Thats what i thought he ment but i cant see how you can do that 5 times unintentionally so i thought it was typed wrong. wtf lol Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted February 26, 2010 Basically they only went in halfway and then twisted themselves off, guess the threads in the holes must have been real damn rusty...So rusty that the screw extractor snapped off as well. Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted February 26, 2010 WD40 first? Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted February 26, 2010 yeah after the first one snapped i chucked some crc in the holes, then after the second one i soaked the bolts as well as the holes with penetrating oil, and still more snapped off. Guess the only thing i can do is engineer really, will call some on monday Quote Share this post Link to post Share on other sites
central3 31 Report post Posted February 26, 2010 One way to remove is to drill pilot hole into the centre of the broken bolt. Then drill this hole out to the thread tapping diameter (7.5mm for an 8mm bolt). Once you have done this you can re-tap the thread. If you damage the thread (e.g. pilot hole off centre) you can drill/tap oversize and fit a heli-coil. For the broken off extractor heat is the only option but not on a bonnet - good luck with that one. Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted March 1, 2010 Well got it done, 2 bolts on each side, one hole screwed up, one with a screw extractor in it. Just drilled out the bolts slightly then forced the normal bolts to self tap and its all good. Still have the weird thing with the fuel pump going on again if any electrics are turned on before engine start. guessing its just the fuel pump relay, as the relay is very very noisy. (Louder than pump by far) Quote Share this post Link to post Share on other sites
