joshnz 2 Report post Posted March 4, 2010 Just blown mine completely, anyone got a half decent not hundreds of dollars suitable for E30, IIRC I'll need something around 3.64. Shipping to Palmy Nth PM me Cheers. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted March 4, 2010 have a 4.45 if you cant find anything else Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 Cheers mate. Anyone who is floating around ... would an E36 diff fit in a E30? they look identical pretty much in size and mount points etc Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted March 4, 2010 never seen an E36 but from what ive been told the E36 one has two mounting points on it while the E30 has one. Except the E36 compact which essentially has the same rear end as E30. Someone more knowledgable will confirm or otherwise though Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 http://www.trademe.co.nz/Browse/Listing.aspx?id=275325602 Is what im looking at Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 4, 2010 Yeah it will fit, must be from a ti if it's E36. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 4, 2010 (edited) Obviously you have seen this, bit far away and shipping is $$$ tho http://www.trademe.co.nz/Trade-Me-Motors/C...n-274405422.htm 4.44 is really short for a 325i though...good luck was bad enough when I had one in my 316i Edited March 4, 2010 by Forrest Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 Obviously you have seen this, bit far away and shipping is $$$ tho http://www.trademe.co.nz/Trade-Me-Motors/C...n-274405422.htm 4.44 is really short for a 325i though...good luck was bad enough when I had one in my 316i Yeah that is what I thought, just waiting for a reply on the link you posted - thats my unanswered question. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 4, 2010 That diff is being sold by Grant on here, same user name, gps289. If he says it's ok it will be. Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 That diff is being sold by Grant on here, same user name, gps289. If he says it's ok it will be. Ahhh very good, now I just have to get it down here Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 4, 2010 Dutchy may be able to help, bmrmad. Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 Thanks for the help guys Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted March 4, 2010 shouldn't you be looking at getting a medium case diff for a e30 325i not a small case one. also you can get a medium case diff from a e28 and swap over the back plate to fit it into a e30 . Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 4, 2010 shouldn't you be looking at getting a medium case diff for a e30 325i not a small case one. also you can get a medium case diff from a e28 and swap over the back plate to fit it into a e30 . You need the E30 output shafts as well if you do the swap, or you can use med case E34 output shafts, they're the same as the E30. Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 shouldn't you be looking at getting a medium case diff for a e30 325i not a small case one. also you can get a medium case diff from a e28 and swap over the back plate to fit it into a e30 . I wouldn't have a clue Brent, looking for a quick solution so I don't have to use the mrs terrible car to get to work and back, car pooling is not an option here lol. Would rather get something I can chuck straight in there and go Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted March 4, 2010 pics of small case and medium case Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 4, 2010 I wouldn't have a clue Brent, looking for a quick solution so I don't have to use the mrs terrible car to get to work and back, car pooling is not an option here lol. Would rather get something I can chuck straight in there and go The small case are fine, mate of mine puts 300 hp thru with no problems yet. Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 Cheers guys, just waiting for Grant to get back to me hopefully will have it sorted soon. Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted March 4, 2010 Got a 4.10 in the shed-probably rev your nuts off tho Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 4, 2010 (edited) I'm pretty sure I've still got a 3.64 : 1 here...I'll have a look Edit: Yes I have... I've had the back off this one...all good inside and I've also put new side seals in it and new diff oil. Was going to use it in the Ti before I changed the ratio and put the LSD in. Its a medium case diff. $250...its yours Edited March 4, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted March 4, 2010 (edited) Turns out its not my diff, have damaged the right rear axle shaft, rubber boot going to diff has blown/torn, grease everywhere underneath, now I'll have to source one of these [edit] f**k knows how this happens? i dont drive it that hard .. Edited March 4, 2010 by Josh_ Quote Share this post Link to post Share on other sites
