crazyarab 6 Report post Posted March 10, 2010 (edited) You sir are my f**king hero... that is EXACTLY what I have in mind... Edited March 10, 2010 by crazyarab Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 10, 2010 Bag / cat post: Throw the kit on too: RS211 16x8 Et11, for reference... Same car on 17x8.5 ET13 RS212's: BBK's work fine with RS' if you wanna run spacers. We're not raining on your parade Atta, go with what YOU want, not us, it's not our car! This is what i want...in black of course. Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 10, 2010 5 stud conversion will probably be the best option after thinking about it Yeh? The 4 lug re-drill going to be too costly? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 10, 2010 Sorry Atta I wasn't hating, just forgot to add the sarcasm font As with your previous history it is going to look hella awesome whatever you decide to do Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 11, 2010 (edited) Ok, for those in the know I need some expert advice. Will the following work with minimal guard roll: 16x8.5 ET14 16x8.5 ET35 18x9 ET20 Also, it's quite likely I will need to get spacers to clear the big brakes so will want a buffer on the offset. From my understanding... the threshold for an E30 is ET 15 - 35 So, all the above should theoretically work expect ET14 is going to be cutting it too close if spacers are needed (assuming adding spacers decreases the offset further)? Edited March 11, 2010 by crazyarab Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 11, 2010 Question was that newbie ay.. ok, will keep researching. Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted March 11, 2010 (edited) For reference, a brembo BBK with BBS RS of an offset of 13 needs a 20mm spacer. 16x8.5 ET14 = 9mm less inner clearance, extra 29mm outside 16x8.5 ET35 = 30mm less inside, extra 8mm outside 18x9 ET20 = 21mm less inside, 29mm outside Edited March 11, 2010 by Ari Gold Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted March 12, 2010 Depends on bell height of the rotors, and caliper "bulkiness. The offset of the wheel doesn't always mean that the wheel can clear brakes. Usually, the more dish there is, the less chance the wheel will have "x factor" to clear calipers. I tried 16x7 RS's at 33p and 20mm spacers and they wouldn't even come close to fitting over my brakes. Where-as various Volk/SSR wheels at higher offsets fit the brakes just fine! I can help, but need details - if you want to keep them secret, PM me. Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 16, 2010 (edited) Right, thinking of picking up this set now.. http://www.trademe.co.nz/Browse/Listing.aspx?id=278149439 2 x BBS RS 137 5 x 114.3 stud pattern 16 X 7" 45 Offset 60.1mm hub 0.5" drop lips 2 x BBS RS 225 5 x 114.3 stud pattern 16 x 8" 45 Offset 60.1mm hub 1" drop lip Seems like these came off a civic or some other front wheel drive car judging from the high offset. To get this to work I will of course have to get them to the right PCD, source the largest spacers I am legally allowed (27mm?) which also have hub centric rings to fill up the larger centre bore back down to 57.1mm. In theory if this all works out it should work quite well as I need huge spacers to clear BBK's anyhow and this will decrease the offset to something acceptable on an E30 leaving me as much room at the guards as possible for future expansion (bigger sexier outer lips). It's going to be costly as **** but hopefully worth the effort in the end. Anyone see any immediate issues I have not accounted for? Edited March 16, 2010 by crazyarab Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 16, 2010 I think the 60.1mm CB could be from a Toyota of some sort Old supra wheels maybe? The spacer size will have to be spot on... Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 16, 2010 I think the 60.1mm CB could be from a Toyota of some sort Old supra wheels maybe? The spacer size will have to be spot on... Why is that? Think it will be cutting it close on the outer guards? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 16, 2010 In the rear...The inside of the wheel more than the outside lip? If the spacers are too small the high offset could cause problems...i couldn't tell you without pics Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 16, 2010 (edited) In the rear...The inside of the wheel more than the outside lip? If the spacers are too small the high offset could cause problems...i couldn't tell you without pics Will definitely need some big spacers at the rear no doubt, probably going to mean that I can't get much dish going? Edited March 16, 2010 by crazyarab Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted March 16, 2010 Could always use hub adaptors like Jib is using. Will space them out and change to 4x100 at the same time. Here's one I prepared earlier Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 16, 2010 (edited) Could always use hub adaptors like Jib is using. Will space them out and change to 4x100 at the same time. Here's one I prepared earlier Oh yeee, that could be an option .. $450! ouch also these are 5x114.3 Edited March 16, 2010 by crazyarab Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted March 16, 2010 These? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 16, 2010 These? Quote Share this post Link to post Share on other sites
APT 204 Report post Posted March 16, 2010 These? Can u get spacers 4x100 to 5x114 ? Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted March 16, 2010 (edited) Yep, you've pretty much got it Atta. The mags are ET45. So if those spacers posted are 20mm or up to 25mm your sweet! IMO those are pretty cheap for hub adapters compared to some I have seen. Those ones have been on trade me for ages. Just had a look and you'd be looking are around 340USD not including shipping for 4 hub adapters from the states, don't know local availability. The only thing you're going to find out with those hub adapters is how the hub size and wheel centerbore will work. If the adapter has already been made to those spec's then your pretty lucky but i'd check it out first. Btw, you do know you need a cert for spacers or hub adapters. So thats another $400! It does add up, you've just gotta figure out whether the final result will be worth the screwing around or whether its better to wait around for the perfect set of wheels (But that could never happen!). Although these mags are very cheap! Edited March 16, 2010 by Nick021 Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 16, 2010 Just to confirm, will any 16" bbs rs lip (34 bolts) fit on these or do I have to hunt down lips for this specific model? Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted March 16, 2010 (edited) any will fit, if you want to save on shipping I'll be placing another order some time next month Edited March 16, 2010 by Jamez Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 16, 2010 any will fit, if you want to save on shipping I'll be placing another order some time next month Keep me in mind, I may very well go ahead with this.. Just need to confirm a few more things. Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted March 17, 2010 snooz ya loose i guess, someone on here snag them? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 17, 2010 That was quick. Anyone else here have some BBS RS at Arrow wheels, aparently theres a couple sets there now! And there were none a few weeks ago when i took mine in Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted March 17, 2010 Does anyone know what offset is needed for when an e30 is converted to 5 stud using e36 Ti rear end? Maybe different with the z3 too? Quote Share this post Link to post Share on other sites
