e30ftw 432 Report post Posted March 13, 2010 (edited) NOOB when it comes to M50's have had a search around and can't find anything useful. Basically motor runs. The idle is Veery high, sits between 1500rpm + going up then cutting off and droping down again then back up to around 2200rpm. After leaving it a while it will shoot up over 3000rpm. What I have done so far is replace the hose from FPR to the intake manifold. Change vacuum hose from PCV oil breather to intake manifold. There aren't any other small type vacuum hoses I can see, so other than that looks like the only ones are brake booster and ICV hoses, PCV etc. Fuel evap line is blocked off. Have tryed running it with the brake booster line blocked off, Made no difference. I'm about ready to pull the intake manifold off and replace every damn seal / gasket and hose. Will upload video soon. Video: http://www.vimeo.com/10129695 Edited March 13, 2010 by e30ftw Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 13, 2010 I suggest before you start taking it apart, wait for someone to give you advice otherwise you will be doing double the work if it could just be something else. Measure twice, cut once.... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 13, 2010 I suggest before you start taking it apart, wait for someone to give you advice otherwise you will be doing double the work if it could just be something else. Measure twice, cut once.... +1 Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted March 13, 2010 Wasn't meaning I was actually going to. Bu lack of advice or anyone knowing WTF is going on = gotta start somewhere. Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted March 13, 2010 Does it ever settle down? When I first put mine in whenever I would turn it on it would rev up to about 2200rpm and sit there or go up and down up and down for about 20 seconds then would flatten out and idle fine. Finally figured it out, and it was the TPS. Just changed that and it worked fine. Try unplugging it and seeing if it makes any difference. That revving seems to be just a bit too crazy for just a vacuum leak, but I'm no pro. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted March 14, 2010 Nah it gets higher and higher then hits and stays at 3500rpm. I tryed heaps of things now and couldn't figure it out.. unplugging TPS didn't do much from what I remember. Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted March 14, 2010 umm happened to me. throttle line was snagged. and was taken out of the holder thing. mine would just stay at 3k rpm and would not go down. re seated the throttle cable and it was all sweet again.. different to your one dropping and going up though... Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted March 14, 2010 (edited) Nah, my throttle is remaining closed at all times so it is not the throttle cable being too tight or stuffed or anything. I've tested the TPS now and it's working correctly as per the Bently.. Edited March 14, 2010 by e30ftw Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 14, 2010 Was the motor running / driving properly before you brought it ?? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 15, 2010 (edited) sounds like airleak to me, or maby tps or something similar, edit just checked vid. doesnot sound like an airleak. check tps maf sensor, also mabey issue in the ecu. but it definalty seems something computer or sensor related. Edited March 15, 2010 by sydwayz e30 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 15, 2010 The problem is unmetered air. Manifold vacuum will be siltch. Either the brake booster vacuum line or crankcase ventilating system has been compromised or items that should be there have been removed on the conversion. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted March 15, 2010 The problem is unmetered air. Manifold vacuum will be siltch. Either the brake booster vacuum line or crankcase ventilating system has been compromised or items that should be there have been removed on the conversion. No. As said, I blocked of brake booster line and it did the same - eliminating brake booster being the leak. TPS tested out fine. All items are there the PCV system remains, the only change was fuel evap delete and that line is blocked off into the throttlebody. The issue is ICV. I blocked it off and the car runs with throttle slightly open. If throttle closed car dies.. But I can get it to idle fine with foot on the throttle. Revs fine etc now. But have now found an even bigger problem thats nipped me in the butt.. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 15, 2010 not quite, you really should listen to glenn you know. i suspect the icv is just making it go crazy because the computer detects a fault somewhere and is trying to rectify it by making the icv go crazy, it may be possible that the icv is f**ked but i dont think that would be the case. but hey you never know. icvs dont usualy have that sympton when they play up, i think there is another fault and the ecu is using the icv to try and rectify it. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted March 15, 2010 Well hey I'm not too worried at the moment. Have to take it all completely apart now anyways. Not good.. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted March 15, 2010 ^Wheres that? Coolant leak from the HG? Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted March 15, 2010 Stink about the headgasket leak bro. You can just remove the ICV, Troy did on his one and just blocked it off or whatever and his car literally idles perfectly. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 15, 2010 The problem with the running issue is "unmetered air" Have you got a better picture of the coolant leak ? Quote Share this post Link to post Share on other sites
