shaQ
BMW 318IS SR20DET conversion
Just started my conversion about 2 month ago now :)
brought a fully rebuild sr20det and started doing the conversion
List of jobs to be carried out on BMW/sr20det.
1. remove complete front of car for motor removable and fabrication
2. remove motor and gear box
3. hydro blast engine bay
4. cut and weld unwanted tabs and brackets
5. prep and paint engine bay
6. hydro blast motor and box
7. fab. motor mounts (2)
8. fab. trans mounts
9. fab. drive shaft
10. fab. drive safty hoops (2)
11. fab. sr-20det t3-4 long runner exhaust manifold/ v-band w/g port
12. sort turbo / waste gate
13. fab. down pipe
14. fab. wast gate plum back set up
15. remove old fuel lines
16. fab. exhaust system
17. fab. new fuel lines
18. sort fuel pump / mod in tank mount
19. sort intercooler / mount
20. fab. intercooler piping / bov
21. fab. air intake pipe / pod filter set up
22. fab. breather tanks
23. install rocker stoppers
24. prep / paint / install valve cover
25. fab. throttle cable
26. sort and fit bmw manaul pedal box
27. sort and mount clutch master
28. fab. clutch line bmw to sr
29. fab bmw to sr computer mounting brackets
30. re wire bmw to nissan enginr loom
31. sort / fab. bmw to sr power steering lines
32. sort / /fab. turbo oil and return lines
33. sort alloy rad and fab. muonts to chassis
Sorry about photos :) all the photos i could find at the moment, car should be done by next week :)
Edited by shaQ
Wow, that's crazy. So many skilled fabricators popping up on BS at the moment.
I'm a noob, but that turbo looks pretty massive. What's your power goal?
It should easily get 280KW with the set up :)
I will post once dyno has been done
Edited by shaQ
Looks good man. What was the sr20det out of and what turbo are you running? Looks to be a tidier transplant than mine :)
Looking forward to seeing the final result.
From a s14 silvia black top sr20det :) it came with this goodies
- polished oem pistons with new ring sets
-shotpeened oem rods with ARP studs
-ACL race series big end and main bearings
-polished crankshaft
-3 layer steel headgasket.
-3 way valve cut on in and ex valves
-new front and rear main seals
Turbo is master power has been modified so it would spool much faster :)
Edited by shaQ
Very nice fabrication - I agree! Am keen to see how this turns out.
Mint! I prefer Jap motors any day. Just a shame they cant make a better all round car thats as good as BMW's tho.
Video please, after its done. Love to hear how it'll rev
Dam- I wish my tig work looked like that
Car started red but is black. Did I miss something?
Yes it use to be red now its pearl black now :)
I need new wheels :(
Remember to use a S14 N/A throttlebody if your rocking that standard intake plenum.
N/A ones are bigger ;)
Cool project
Fastcars diff knows what they doing :)
Oooh its your E30 that fastcars are doing! Was speaking to someone at a trackday about it, haha
Small world!
Should be ace when its done dude..
Small world!
Yes e36 :) you probably was talking to a guy name Vince :)
Insurance is a pain though :(
very very nice conversion.certainly should have the goods
thanks :) should be completed by this friday, will post some more photo after :)
Little things that are becoming a problem :( never would of thought it would take this much hard work and time
