curryinahurry 39 Report post Posted March 27, 2010 (edited) Hi, I was wondering if anyones experienced the air cond (interior HVAC system) not turning off? I just came home with the air con running, but even after turning the car off and removing the keys, its still running and I can't really turn it off! Would anyone have any ideas on whats wrong with it and how to fix it? For now, I've removed the battery... Many Thanks! Andrew Edited March 27, 2010 by curryinahurry Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted March 27, 2010 I'd remove the fuse for it, for now so you can atleast operate your car without it being on all the time. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 27, 2010 Hi, I was wondering if anyones experienced the air cond (interior HVAC system) not turning off? I just came home with the air con running, but even after turning the car off and removing the keys, its still running and I can't really turn it off! Would anyone have any ideas on whats wrong with it and how to fix it? For now, I've removed the battery... Many Thanks! Andrew It will need a new heater fan resistor block in the heater housing. This is what gives you your fan speeds... a very common problem Quote Share this post Link to post Share on other sites
