Ben 0 Report post Posted May 12, 2010 Is there any added benefit to having the sway bar mounted on the shock? The reason I ask is I want to shorten my shocks and put coilover sleeves on but the sway bar mount is in the way. Can I just convert my sway bar to bottom mount without any issues? Any help would be appreciated. Cheers Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted May 12, 2010 I take it you have an old 325 with strut mount sways? These have the same control arms as an e36. So mounting them will be no problem. Just get different endlinks There is a good discussion of strut mount sways vs control arm mount on bimmerforums. I'll try find it again I think the gist of it was people found they had a better 'feel' from the strut mount. The only other bennefit was that you can run a thinner sway that weighs less OT/ what strut inserts are you going to use? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 12, 2010 it basically acts much like a lever. if you think of a lever and then imagine the pivot point to be the inner ball joint then the further out from that ball joint the swaybars connected to the more leverage it will have and the smaller the swaybar has to be. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 14, 2010 (edited) thats what i was trying to say in a round about way Edited May 14, 2010 by e30li Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted May 14, 2010 bit of a hijack I know but can somebody provide a decent photo of the strut Mount Swaybar setup ? Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted May 14, 2010 (edited) http://www.uucmotorwerks.com/html_project/...g/sway_bar2.jpg Is there any clearance issues if using an e36ti sway bar (25mm one) on a 6 cylinder? does anyone use adjustable endlinks for adjusting the preload on the bar? Edited May 14, 2010 by bbs Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted May 14, 2010 Ok so considering my shock inserts will be stiffer than stock and the springs are fairly hard at 10kg/550lb, Will the roll stiffness still be noticeable if i used my existing sway bar in the lower mount position? Is there a thicker OEM sway bar I can use to "balance" the suspension? ie. 328i, Msport Thanks for the words of wisdom so far has been very informative Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 14, 2010 IMO its not worth the hassle, if your that anal about getting a bigger sway bar (which i dont think is always a good thing) then just stick with an uprated swaybar in the factory position, too much hasle for no, if not negative gains... Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted May 14, 2010 (edited) Using a 26 mm bar with the direct set up will cause massive sledging (understeer) unless the rear is also significantly upgraded AND all the springs are up rated as well (And all the compression and rebound in the shocks also proportionally increased). Most GOOD aftermarket bars and the BMW M Sport bars increase roll force by 20 to 40% max - direct connecting a 26 mm bar from geared increases it by 100% making it the dominant element in the suspension - so transverse stiffness on the front axle will be way out of proportin with the rest of the suspension. And suspension is all about balance. The M3 runs a 23.6 mm bar from memory direct geared so the bar is about 30% softer than a 26 but when geared directly (100%) it equates to about 40% stiffer than the 2:1 geared 26mm bar. And: what do you mean by pre loading a sway bay it is designed to be "unloaded" when the car is static or going in straight line. early m3's had 22.5mm sways. m3 evo's have 23mm. 25mm was a bad choice to base that on. Instead if one was to use a 23.5mm bar from a 318 would this be an acceptable sway bar? I was wanting to know if people use adjustable endlinks to adjust preload.For me i would like to get rid of any preload caused by changes in corner weight and lower suspension. Or is this not noticable until you go to extremes? Ok so considering my shock inserts will be stiffer than stock and the springs are fairly hard at 10kg/550lb, Will the roll stiffness still be noticeable if i used my existing sway bar in the lower mount position? Is there a thicker OEM sway bar I can use to "balance" the suspension? ie. 328i, Msport Thanks for the words of wisdom so far has been very informative the 328i with motorsport suspension has 25.5mm swaybars What swaybar's do you currently have? Edited May 14, 2010 by bbs Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 15, 2010 Whats peoples take on welding non-insert shock bodys, E36/46 style? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 15, 2010 I'm not so much concerned with distorting the tube as I am with destroying the internals of the shock with the heat generated. Also, are you saying you have had a Koni insert fitted to the 325 shock body? This would have meant cuting the body to remove and replace the insert yes? Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted May 16, 2010 I'm not so much concerned with distorting the tube as I am with destroying the internals of the shock with the heat generated. Also, are you saying you have had a Koni insert fitted to the 325 shock body? This would have meant cuting the body to remove and replace the insert yes? Watch this It explains most of the procedure. The heat shouldnt be too much of a problem if you just weld with a series of spot welds. Otherwise I think E30 shocks use a collar nut at the top of the shock body. Could cut one of those off and weld it to the E36 one maybe. Quote Share this post Link to post Share on other sites
