wolliver 1 Report post Posted May 14, 2010 ok im wanting to move the fusebox in my '87 e30 project. all im wanting to know is there a way for me to move it without cutting any wires, or is that the only way.... it seems the only way that i can see lol. if anyone has done it or knows how, could you let me know. cheers. Wolley Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted May 15, 2010 i doubt youd be able to move it without cutting wires. Id figure out where you are wanting to relocate it and then cutting each individual wire, adding in hew wire to lengthen, and then move on to the next wire. Would be a very slow boring painfull process id say. may find it benificial to pick up a second fuse box from a wrecked car if you re planning to relocate into the cabin so they can be threaded to the firewall. Have fun Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted May 15, 2010 Pick it up - throw over your left shoulder - buy a E36 Problem solved Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 15, 2010 (edited) yyyyyyeeeeeaaaahhhhh.. NA... not happening without chop chop i moved mine, i cut the wires goint to the headlights, wiper etc and extended them as required, that is by far the smallest part of the loom to cut... Edited May 15, 2010 by e30li Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted May 15, 2010 You could strip the interior and pull the loom out of car then feed it back through.. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 16, 2010 ^but depending on where you put it you will probably find doing that will mean some part of the loom wont reach where its supposed to. Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted May 16, 2010 yyyyyyeeeeeaaaahhhhh.. NA... not happening without chop chop i moved mine, i cut the wires goint to the headlights, wiper etc and extended them as required, that is by far the smallest part of the loom to cut... where abouts did you put your fusebox? i plan on putting it behind the glovebox, just means ill lose half my glove box Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 16, 2010 thats where mine is, mines a racecar so i dont use the glovebox anyway, you can just get away with keeping the full box on mine, but in saying that my loom is very simplified and i have no heater box etc. Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted May 16, 2010 how did you mount it? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 16, 2010 the screwed it to the firewall, there is a box section peice of the firewall that runs just below the windscreen right across the car, the bit that has the big L shaped bracket coming off it when you take the dash out. i just screwed the mounting screw onto a tab that was on there. Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted May 17, 2010 didnt really know where abouts i could mount it on the L bracket thing, so i put it here Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 18, 2010 that works. mines sitting on that tab you can see for the earth at the front of the picture. Quote Share this post Link to post Share on other sites
