Ben 0 Report post Posted May 16, 2010 (edited) Ill keep it short and sweet.. I maybe getting some new rims shortly and Im going to need BIG CAMBER to fit them so... a ) Will adjustable rear camber arms from an E36 M3 fit an E36 325i? b ) is anyone selling them cheaper than $300 a pair? Edited May 16, 2010 by Ben Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 16, 2010 I got a pair of these just the other day. still yet to install them http://www.redlineperformance.co.nz/?actio...;type3=European Quote Share this post Link to post Share on other sites
Heino 1 Report post Posted May 16, 2010 Thanks for the link for the camber arms. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 16, 2010 you know you will probably need a cert for them as well i hope i am not stating the obvious Quote Share this post Link to post Share on other sites
Heino 1 Report post Posted May 16, 2010 you know you will probably need a cert for them as well i hope i am not stating the obvious Yea yea i know thats awl goods . Someone wana help me get my signature working how do i make that picture work it keeps saying "Sorry, dynamic pages in the tags are not allowed" :S Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted May 16, 2010 I got a pair of these just the other day. still yet to install them http://www.redlineperformance.co.nz/?actio...;type3=European I take it they are adjustable? Do you know how many degrees of adjustment they allow for? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 16, 2010 Yes they are adjustable. I'll take some photos and measurements tonight if you'd like Not sure of how many degrees it will change. redline couldn't tell me either. Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted May 16, 2010 Yes they are adjustable. I'll take some photos and measurements tonight if you'd like Not sure of how many degrees it will change. redline couldn't tell me either. Yea that would be awesome thanks Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 17, 2010 My cars current camber arms measure from bolt to bolt (lengthwise) 550mm. With the adjustable camber arms set to the same length as the standard camber arms, the thread inside the shaft is 23mm either side. I hope that makes sense If you want any more information about them i am happy to share. Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted May 17, 2010 Thanks heaps for the photos. So I take it theres plenty of thread to give more negative camber then? Does anyone know of a way to calculate how much camber is gained per mm of adjustment? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 17, 2010 difficultly, easiest way is to put it on and try it when its on the w.a machine. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 17, 2010 Most people buy these adjustable control arms so that they can reduce camber in the rear. If you need to increase camber out side the boundary (specifications) to fit wheels, I would suggest your car is far too low or you are fitting wheels that are the wrong fitment (ET & rim width) for your car. Increasing camber in the rear will also put alot more stress on the rear suspension, drivetrain and will wear out tyres real quick. You will also have less grip because of the reduced tread contact area with the road. Quote Share this post Link to post Share on other sites
