Deano 1 Report post Posted May 25, 2010 (edited) Hi Looking for manual pedal box for E36 325. Or just the clutch pedal and slave cylinder I have an E30 manual pedal box could do a part swap Cheers Edited May 25, 2010 by Deano Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 25, 2010 Manual & Auto pedal boxes are the same on a E36. You'll need brake & clutch pedals, clutch pedal return spring, clutch master cylinder, pedal pin & clips, fluid supply hose from brake master cylinder, firewall grommet & the firewall pipe going to the clutch slave cylinder hose if your doing a manual conversion. It might be hard getting these as no one wants to break up a manual conversion kit. You could try Ray @ HELLBM though, he might be able to help. Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted May 25, 2010 Manual & Auto pedal boxes are the same on a E36. You'll need brake & clutch pedals, clutch pedal return spring, clutch master cylinder, pedal pin & clips, fluid supply hose from brake master cylinder, firewall grommet & the firewall pipe going to the clutch slave cylinder hose if your doing a manual conversion. It might be hard getting these as no one wants to break up a manual conversion kit. You could try Ray @ HELLBM though, he might be able to help.Thanks Glen. I see on Ebay there is a guy selling clutch pedals on there own for $15 US. I have an E30 manual pedal box, its very different but the master cylinder looks similar and maybe able to use some of the hardware..just checking at this stage Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 25, 2010 What you need to look out for is that the clutch hardline from the master to the slave cylinder has two different fittings on the master cylinder end. One is a clip on type (later) and one is a threaded type (earlier). The clip on type is the only one avaliable new. I dont know if the e30 master is useable but it only has the threaded connection. Does that make any sense? ha. Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted May 26, 2010 pedals from a left hand drive wont work . needs to be from a rhd car Quote Share this post Link to post Share on other sites
