sascha 17 Report post Posted May 29, 2010 Hi everyone - Ive got a wierd noise coming from somewhere, heres the details, ill explain everything leading up to it incase one of the things may have caused it? I recently changed the oil and filter on my e30 325i, and then towed a trailer to St Heliers and back to Orewa. On the way back I heard a slight grinding/groaning noise coming from the engine bay (I think) when I pushed the clutch, its a hard noise to describe. It got stronger and stronger since then, but its only there when the clutch pedal is depressed. You can feel the noise (if you know what I mean) on your foot when you push the clutch pedal. Is it the clutch? I havent noticed any slipping, and the gears dont crunch. Just doesnt sound good when pushing the clutch pedal. Good timing just as I've put it up for sale, so would like to get this fixed asap Cheers for your help Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 29, 2010 Sounds very much like youve got a faulty clutch release bearing or the pressure plate diaghram has a broken finger Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 29, 2010 ^yep, will be one of the above... dont leave it until it completely fails otherwise you will probably have to grind the melted release bearing off the input shaft. this happened to me once.. Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted May 29, 2010 ^yep, will be one of the above... dont leave it until it completely fails otherwise you will probably have to grind the melted release bearing off the input shaft. this happened to me once.. How much are replacement release bearings btw? Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted May 29, 2010 How much are replacement release bearings btw? I got it in a clutch kit from auto clutch, when i bought it it costed like 220 all up for a m20b25 clutch kit, release bearing was approx 30 - 40 bux prices might be different now Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted May 29, 2010 Sounds very much like youve got a faulty clutch release bearing or the pressure plate diaghram has a broken finger Ok sweet, how much is it roughly to get that fixed? Cheers Quote Share this post Link to post Share on other sites
e30ftw 419 Report post Posted May 29, 2010 You will have to pull the gearbox out and while your there replace the whole clutch assembly, not just the thrust bearing.. As in buy a clutch kit and replace the disc, pressure plate and thrust bearing. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 30, 2010 allow for about 800 at a garage.. inc labour and parts... Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted May 30, 2010 $800? ohh mann! there goes my course related costs.. Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted June 8, 2010 fixed thanks too ray at hell bm Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted June 8, 2010 fixed thanks too ray at hell bm Was it the release bearing ? or some thing else Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted June 15, 2010 Was it the release bearing ? or some thing else It was the thrust bearing. Is that the same thing? Quote Share this post Link to post Share on other sites
e30ftw 419 Report post Posted June 15, 2010 Yes. Did you replace the whole clutch assembly? Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted June 17, 2010 Sweet. Nah Ray had a look at it he said and it looked like there was still plenty of clutch left, and it wasnt worth replacing it. Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted June 17, 2010 Mine needs replacing, how much did it set you back by chance? Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted June 17, 2010 Mine needs replacing, how much did it set you back by chance? PM'd Quote Share this post Link to post Share on other sites
