e30ftw 433 Report post Posted July 1, 2010 How does the front drive belt go on? I have tried it every way I can think of and it's loose as f*ck, tensioner pulley does nothing. I only pulled it off cos It was too tight to fit around the PS pump so took the whole thing off to start from scratch. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted July 1, 2010 like this Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted July 1, 2010 (edited) Ok, so how do you put it on that way? I can't get it around all 4 pulleys + the middle one, let alone the tensioner too. Edited July 1, 2010 by e30ftw Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted July 2, 2010 take the little plastic cover off the tensioner pulley the rest is pretty much self explainitory Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted July 2, 2010 if you brought it from repco, thier catalouge lists the wrong belt. you need either the one size bigger or the one size smaller. At least that happened to me Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted July 2, 2010 (edited) Whats the easiest way to get it on? Reset the tensioner position, put the belt on and release the tensioner...not hard to do Edited July 2, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 2, 2010 Ooops..that should have been a reply... not an edit... sorry John Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted July 2, 2010 Ooops..that should have been a reply... not an edit... sorry John I couldn't get it over the 4 pulleys then across over the middle one and that was with the tensioner off. Maybe the pump isn't on properly or something.. Don't see how though. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 2, 2010 Have you loaded the tensioner so that it can tension the belt once it's released ? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted July 2, 2010 Have you loaded the tensioner so that it can tension the belt once it's released ? Is the middle one the tensioner? I can't see anything cos of how close it sits lul .. If so then whoops. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted July 2, 2010 yea its the middle one man Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted July 2, 2010 Ok f*ck that , spent all morning putting the sump and subframe in before work and i couldn't even figure out the belt right at the end haha. Fail. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted July 2, 2010 MSN to the rescue ahaha. go to it Quote Share this post Link to post Share on other sites
