swordfish
"Lemforder" front wheel bearings/hubs for E36/E46 Z3&Z4
A bit of the back ground information: Worn wheel bearings is a common problem on BMWs due to the way the actual wheel bearing is constructed. Usually, the car starts making weird noises (squeaking, wowing etc). The car will become less smooth, might get a vibration in the steering wheel and so on. If your wheel bearing is worn the main danger is that it can fall apart at any time and if it does, it will lock the wheel and you can end up somewhere where you definitely don't want to end up. So it is a good idea to prevent this by changing them before they have totally worn out.
Genuine Lemforder two front wheel bearings and hubs.
Made in Germany! The best quality you can get, direct OEM replacement of the original BMW ones.
Part suits E36 92-99 318/323/325/328/M3
E46 99-05 323/325/328/330 (not M3 or XI models)
Z3 96-02 All models including M-Coupe/Roadster.
Usual price $240 each
Will sell for $200 each; bimmersport member special! Trust me this is the cheapest you will get in NZ.
Plus extra delivery cost if required.
I am located in Christchurch city so if you like you can have a look at them.
Cheers
P.S. Have genuine BMW lock nuts for them too if you need for extra cost.
Edited by swordfish
I could be keen on these, but money's a bit sparse atm. Will get back to you about em as soon as i've got the dosh.
Ok. Keep me posted.
Is that $200 for both or for each? your post doesn't state that. :)
Good point. "Each" everybody :)
Edited by swordfish
Bump! Price down to $190 need garage space.
Edited by swordfish
Last bump! Will let them go for the lowest I can $185 otherwise will leave them to myself.
Still available $185 each... have two all together. Please note it is a bearing and a hub together not just a bearing!
Need money please buy them off me :) $175 each, this is lower than I bought them for!!!
