dubman 39 Report post Posted July 15, 2010 (edited) Car's off to the painters for the week, so started workin on tweeters. I'm not pointing the tweeters at the seating positions, because i heard that this causes "harshness" when music's playing. Is this the case? Also, which tweeter would you pick? Tweeter 1 Tweeter 2 Held by blu tak atm Edited July 15, 2010 by dubman Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted July 15, 2010 (edited) #1 dude-lks nice & factory What brand are they-my stock ones are fkg average lol Edited July 15, 2010 by 1rotty Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted July 15, 2010 Tweeter 1 Or you could try and source some actual e30 tweeter pods. Looks much cleaner imo. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 15, 2010 #1 Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 15, 2010 im going no.1 @ 1rotty/Mark: they are Clarion, came in a 5.25' component package @ _BRS_/Blair: cant afford them , especially ~$100 a pair from recent TM auctions Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted July 15, 2010 They'll look good mate-direct them slighty up(ear height) Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 15, 2010 They'll look good mate-direct them slighty up(ear height) Thats the factory pod aim IIRC? These swivel around in their casing, so can adjust direction. Cheers for the input so far guys, much appreciated. Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted July 15, 2010 Definitely 1 Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted July 15, 2010 1 Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted July 15, 2010 id say 2, soley for that mean overlap going on. that looks awesome Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted July 15, 2010 1 definitely Quote Share this post Link to post Share on other sites
isis 16 Report post Posted July 15, 2010 why not try and incorporate it into the pillars? they look great there too. Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted July 16, 2010 Figure out where the tweeters go last. get the rest of the system sorted and then try the tweeters in a variety of positions using blutack to hold them in place. Get Michael Jackson Thriller and listen to where the footsteps are - he should walk across your dash. Every tweeter has different on / off axis response so try them and see where they sound best to you. Also try inverting the phase of both tweeters (ie wire the negative tweeter wire to the positive crossover terminal and vice versa) to see what effect this has on the apparent height of your sound stage. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted July 16, 2010 what i am going to do is build tweeter pods into my front vents on the dash. either on the side vents or the center vent. not too sure yet.. some food for thought. Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 16, 2010 Get Michael Jackson Thriller and listen to where the footsteps are - he should walk across your dash. Every tweeter has different on / off axis response so try them and see where they sound best to you THANKS! yea, all the speakers already in the stock positions, just need to wire it using supplied wiring. Upgraded fronts only, left the rear Aiwa 2 way/coaxials as it is. Awesome idea of using Thriller. Cheers Rogan. what i am going to do is build tweeter pods into my front vents on the dash. either on the side vents or the center vent. not too sure yet.. some food for thought. I thought about installing them into vents, but too much work at this stage. You can also put tweeters into where the manual window handle goes, but you need electric windows and change your door cards into manual ones. Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted July 16, 2010 You don't really want to put the tweeters into the vents or where the door winders are. Good idea is to minimise the path length difference between the tweeters and the listener, so in a nutshell put them as far away as possible (I'm not going to get into reflections cos it'll complicated things) If you've got time, have a read of this (page 7 onwards): http://hybrid-audio.com/downloads/Hybrid%2...rs%20Manual.pdf It's an indepth, but not too hard to read, analysis of speaker positioning. Focusses on the HAT L3 but is applicable to all speakers. Quote Share this post Link to post Share on other sites
