keen 6 Report post Posted August 4, 2010 can someone tell me how or what to check to fix reverse lights which are intermittent in operation? And the fuel gauge is still sitting on full and not coming down. I always fill the tank right up at each refuelling and for some reason this time its stayed there. Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted August 27, 2010 My fuel gauge sometimes flicks up to full when I go over bumps (I never fill it up though) and it stays there. I simply bang the speedo and it will go back down. As for the brake lights, no idea--but you could unplug them? Mine dont work & have passed 3 wofs so far. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted August 27, 2010 Reversing lights aren't a WOF requirement, unless only one goes or some BS like that... ask Glenn Is the car automatic or manual? check the connection around the transmission selector, I think that's where the switch wires are. As for the Gauges... pull the cluster out and tighten up the brass nut on the back, it's the earth for it. (even give the nut a sand down or something like that) Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 27, 2010 Reversing lights aren't a WOF requirement, unless only one goes or some BS like that... ask Glenn Alot of the testing stations are now pinging you for reverse lights & rear fog lights. Its a bit of a cockup realy because half the AVI's don't know their cars. Alot of the cars now come out with one fog light on the R/H side & one reverse light on the L/H side. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 28, 2010 To my knowledge it is - if a light is fitted - it MUST work. Meaning reverse light lenses - lamps should work Quote Share this post Link to post Share on other sites
crazycooter 0 Report post Posted September 8, 2011 To my knowledge it is - if a light is fitted - it MUST work. Meaning reverse light lenses - lamps should workyes thats right i am an avi . if its there it must work Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted September 8, 2011 can someone tell me how or what to check to fix reverse lights which are intermittent in operation? And the fuel gauge is still sitting on full and not coming down. I always fill the tank right up at each refuelling and for some reason this time its stayed there. steering back on track, to OP check the reverse switch, failing that give me a yell cheers Jon Quote Share this post Link to post Share on other sites
