Tristan 338 Report post Posted September 21, 2010 Hi I was wondering how much I would be looking at to replace the single pipe with a dual outlet without modifying the rear bumper? And also will this change the exhaust noise at all? Preferring cheaper options, if possible also advantages and disadvantages of different options. Cheers Tristan Quote Share this post Link to post Share on other sites
AN E30 Fan 1 Report post Posted September 21, 2010 Your best bet is to go to a Muffler shop and talk to them, I have heard great things about these guys - http://www.woolfmufflers.co.nz/ Unless someone else has done the same thing on here I doubt you will have much luck getting a quote. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted September 23, 2010 Cut & reduce the size of the rear tire well, then put an M5 rear exhaust setup on it, best way to do it. Then get one of those M5 puncture repair kits since you wont have a spare. Quote Share this post Link to post Share on other sites
39KiwiTouring 2 Report post Posted September 23, 2010 Room would be the issue M5 idea would be best, pretty busy under the E39 not alot of room. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 23, 2010 Cut & reduce the size of the rear tire well, then put an M5 rear exhaust setup on it, best way to do it. Then get one of those M5 puncture repair kits since you wont have a spare. Not such a good idea as in NZ you need a spare tire if you car came with one to get a warrent. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted September 23, 2010 (edited) Are you sure this is right? http://www.aa.co.nz/motoring/tips/ask-jack...d-no-spare.aspx AA could be wrong. I've been through a few warrents with no spare tyre in the boot. I could have been lucky. While it may look nice there isn't really a need for quad pipes on a 325 Opt for the 335i ... or are you talking about just changing the tip? Edited September 23, 2010 by bbs Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted September 23, 2010 Are you sure this is right? http://www.aa.co.nz/motoring/tips/ask-jack...d-no-spare.aspx AA could be wrong. I've been through a few warrents with no spare tyre in the boot. I could have been lucky. ... or are you talking about just changing the tip? Just tip. Quote Share this post Link to post Share on other sites
nigel_1981 0 Report post Posted September 29, 2010 Not such a good idea as in NZ you need a spare tire if you car came with one to get a warrent. Last time I checked that was not the case. If you have a spare it must be located correctly, have enough tread etc.. I could be wrong but no spare, no problem. Quote Share this post Link to post Share on other sites
bmpower 3 Report post Posted September 29, 2010 Pretty sure the only requirement for a wof regarding the spare is that if there is a spare wheel, it must be secure. Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted September 29, 2010 Time to get a set of run-flats Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted September 29, 2010 Pretty sure the only requirement for a wof regarding the spare is that if there is a spare wheel, it must be secure. I got this impression too. I've passed with out spares in the past. Quote Share this post Link to post Share on other sites
