richx 0 Report post Posted March 28, 2005 i want a turbo i gotta 1988 320i and i want a turbo in it, could anyone give me some advice on what the cheapest and easiest engine to put in Does that sitdwn bimmer have a 4agze? how much would that cost to do? any advice handy... cheers Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted March 29, 2005 turbo the motor already in there.. 4000 - 6000 depending on your engine management solution. Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted March 29, 2005 theres your solution ..... ................yea bitch! Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted March 29, 2005 what is the point of doing it on the cheap? everyone thats says it, redoes their car 6months later saying i should have bought the more expenive bit which would last longer and say you money in the long run. 6000g. same as andys comment. Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted March 29, 2005 for a turbo here is the advice. listen carefully. fast. cheap. reliable. pick two. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted March 29, 2005 double the labour!!!! money well spent doing the samething or just vtec it!!! Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted March 29, 2005 get a rota hah, jump on hurr might learn something seriously though, toyota 3sgte in there, w55 gearbox.... your away laffin, much stronger than m20. :pimp: Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted March 29, 2005 E30 turbo setups http://jdturbocharging.com/27339/11701.html Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted March 29, 2005 $6000 at least! engine management $1400 + (for a good one) turbo $ 300 - 1000 (for a good one) intercooler $ 300 - 500 (for a good one) manifold $ up to $800 depending on what its made from now you have to decompress your engine can you do this or do you need to pay someone to do it??? (btw andy and anyone else doing this theres a shop in paraparaumu that will make a head gaskit you your specs cheap) so there you are your up around 3- 4000 already and the work hasnt even started... exhaust ... intercooler plumbing ... wiring ... blaa blaa blaaaa but hey if you want to do it good luck im sure there are lots of people on here that would help you on the way. you know you could just put a 13b in it ... haha Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted March 29, 2005 I'm not so sure i'd bother with lowering the compression using a head gasket - the compression is pretty low any way 8.8:1 . Quote Share this post Link to post Share on other sites
