OP6 27 Report post Posted October 6, 2010 After a performance chip for a mate with a 1989 535 manual, or alternatively suggestions on what will give the best bang for the buck. My mate has buggar all money but a couple of pfl and fl E30's which he is wrecking. Trade? Quote Share this post Link to post Share on other sites
Jacko 2397 Report post Posted October 6, 2010 After a performance chip for a mate with a 1989 535 manual, or alternatively suggestions on what will give the best bang for the buck. My mate has buggar all money but a couple of pfl and fl E30's which he is wrecking. Trade? Tried EBay? I picked up a chip from a guy sapporo10 http://feedback.ebay.com/ws/eBayISAPI.dll?...tab=AllFeedback Cost me around $50NZ for a euro spec'd M50B25 chip, took a week to turn up in a 3M antistatic box, comes with very detailed instructions too. I havent installed it yet, but he has some great feedback so I expect it will be at least a half decent map. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted October 6, 2010 Tried EBay? I picked up a chip from a guy sapporo10 http://feedback.ebay.com/ws/eBayISAPI.dll?...tab=AllFeedback Cost me around $50NZ for a euro spec'd M50B25 chip, took a week to turn up in a 3M antistatic box, comes with very detailed instructions too. I havent installed it yet, but he has some great feedback so I expect it will be at least a half decent map. with the ol M30 we have a problem.The NZ new 535 were configured to run on leaded gas,no oxygen sensor and a different ecu than the M 30 in the rest of the world.I have heard that the ecu is the same as the e28,wether this is actually true i dont know. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted October 7, 2010 I think the general consensus for "bang for buck" in the early injected engines (regardless of model) is, in increasing order: (and correct me if I'm wrong guys ) Cold air intake Headers/extractors - exhaust side Remap (a la Hi Velocity) MAF delete and MAP ECU replacement (tune, etc ....) Turbo (tune, etc ....) Engine swap .... Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted October 7, 2010 with the ol M30 we have a problem.The NZ new 535 were configured to run on leaded gas,no oxygen sensor and a different ecu than the M 30 in the rest of the world.I have heard that the ecu is the same as the e28,wether this is actually true i dont know.no e28 completly different ecu setupE34 535i ECU similar to E30 325i.no , similer box to late 325i e30 but different programming etc I think the general consensus for "bang for buck" in the early injected engines (regardless of model) is, in increasing order: (and correct me if I'm wrong guys ) Cold air intake Headers/extractors - exhaust side Remap (a la Hi Velocity) MAF delete and MAP ECU replacement (tune, etc ....) Turbo (tune, etc ....) Engine swap .... yes thats about right . there is no cheap hp in these engines , i think a proper remap of the ecu or map-ecu2 add on system is probably the best proformance gain on the m30 engine. also a lighter single mass flywheel and new clutch is a good upgrade to the origanal dual mass flywheel. diff gear ratio change . 3.73 or 3.91 etc Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted October 7, 2010 Agreed. Contact Boris (MrE34) on here for info on these, he is very knowledgeable on such maters and his M535i with the MapECU went very nicely indeed. Quote Share this post Link to post Share on other sites
OP6 27 Report post Posted October 7, 2010 As always, great info and advice guys. Thankyou very much. i shall pass this info on. Cheers Don Quote Share this post Link to post Share on other sites
