ler4_war 1 Report post Posted October 22, 2010 How would you know if your headlight beam is low or high? how will you know if youve adjusted it to the normal range? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted October 22, 2010 Find a flat peice of ground with a perpendicular wall. Drive up to wall, mark where the focused part of you light beam is, roll back a couple meters and see if the beam is focused on the same mark. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted October 22, 2010 low needs to be BELOW horizontal Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted October 22, 2010 Shining the headlamp on a wall - low beam will have a distinct cut off so as not to blind other drivers. Low beams should be the outside lamps. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted October 23, 2010 Aim them up high, if people high beam you at night, aim them down a tad. Repeat until people stop high beaming you at night. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 23, 2010 Aim them up high, if people high beam you at night, aim them down a tad. Repeat until people stop high beaming you at night. Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted October 23, 2010 Or go to a workshop that has one of those headlight testers. Last WOF I done they had one and allowed me to adjust my light while using their light tester then passed the WOF. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted October 23, 2010 The place I goto for WOF's do it for me.... it takes them five seconds. Good service IMO, Makes me go back each time. Quote Share this post Link to post Share on other sites
