[email protected] 0 Report post Posted November 1, 2010 Hi all, I hope someone can shed light on what may cause a strong petrol smell coming from my exhaust? There doesn't seem to be a leak in the fuel line but there is a 'chuggy' idle like too much fuel is getting in....is this the fuel injectors or O2 sensor? Hoping it's a simple fix! Thanks for your help. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 1, 2010 sounds like it could be running rich...from previous cars i've had, easy fix for a car with carby not so easy with injected. Personally i would get the fuel line leak fixed first then see if it continues not to burn all the fuel! Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted November 2, 2010 sounds like it could be running rich...from previous cars i've had, easy fix for a car with carby not so easy with injected. Personally i would get the fuel line leak fixed first then see if it continues not to burn all the fuel! Thanks, at first look I cannot see a leak, but I will have a closer examination...any idea whetre to start with an injected system?Cheers. Quote Share this post Link to post Share on other sites
Jacko 2371 Report post Posted November 2, 2010 Sounds like a stuck injector maybe? Check all the injector electrical plugs are on nice and tight Check for vacuum leaks. Still running rich at idle, id pull the injectors and get them professionally cleaned and flow checked. Gonna be a process of elimination... If its still running rich as at idle id start playing with electrickly trickery, AFM, 0x sensor etc. Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted November 2, 2010 Sounds like a stuck injector maybe? Check all the injector electrical plugs are on nice and tight Check for vacuum leaks. Still running rich at idle, id pull the injectors and get them professionally cleaned and flow checked. Gonna be a process of elimination... If its still running rich as at idle id start playing with electrickly trickery, AFM, 0x sensor etc. Thanks...any idea what it costs to get the fuel injectors cleaned? Quote Share this post Link to post Share on other sites
Jacko 2371 Report post Posted November 2, 2010 (edited) Thanks...any idea what it costs to get the fuel injectors cleaned? Ultrasonic cleaning and testing, bank on around $20-50 an injector. Edited November 2, 2010 by Jacko Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted November 2, 2010 Ultrasonic cleaning and testing, bank on around $20-50 an injector.hmmmm...seems you can buy reconditioned injectors from Ebay for $US69 inc. shipping for 6 19lb 204cc reconditioned injectors......Anyone have experience in this? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted November 2, 2010 Ive seen an e30 m20 run rich when the throttle posistion switch was out of adjustment. Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted November 2, 2010 Ive seen an e30 m20 run rich when the throttle posistion switch was out of adjustment.Thanks Polley..any idea how or where to adjust this? Its funny, I can smell fuel, slight chugger chug noise at idle but idle is pretty consistant at 600-650, could be a bit low, maybe related? Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 3, 2010 here's a couple of good links for you - http://www.bimmerdiy.com/dir/e30 injector cleaning - http://www.pelicanparts.com/BMW/techarticl...or_cleaning.htm Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted November 3, 2010 Check your TPS (throttle position switch) and also your thermostat. Thermostats sometimes seize in the "cold" position which tricks the ECU into delivering too much fuel even though the engine is warm. Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted November 3, 2010 (edited) Thanks Cliff....yes lots of good articles in the Pelican Parts archive, I will check out the other one too. Mark - I assume if the thermostate is seized it can be cleaned with some brake cleaner...also TPS? Cheers. Edited November 3, 2010 by Rhamin Quote Share this post Link to post Share on other sites
polley 916 Report post Posted November 3, 2010 If the thermostat is poked just replace it. Does your car come fully up to temperature, and if it does, does it take longer than normal? Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted November 3, 2010 Thanks Polley...I have only had the car a few weeks...seems to go up to halfway when in traffic and about 1/3 on the open road, seems normal, gets up to operating temp the same speed as my old mazda did. Although I have noticed on the odd occasion that the needle jumps erratically from 1/3 to half temp and back again in quick twitches!! hmmm...thermostat? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted November 3, 2010 1/2 temp is normal operating temp. The gauge flickering around is probally a bad connection in the gauge cluster, its quite common. Try giving the dash a whack next time it does it Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted November 3, 2010 I can't hit my new baby!! lol, perhaps some tender words of encouragement! Will replace the thermostat anyway, they seem reasonably proced, can't do any harm. Quote Share this post Link to post Share on other sites
mark19 0 Report post Posted November 11, 2010 I can't hit my new baby!! lol, perhaps some tender words of encouragement! Will replace the thermostat anyway, they seem reasonably proced, can't do any harm.if the gauge flickering gets worse its quite probably that the grounding nut needs tightning in the back of the instument cluster. Remove cluster, tighten night behind temp gauge (on back of cluster, you dont have to pull the cluster apart), and reinstall. This seems to be a pretty common issue. Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted December 9, 2010 Seems to have stopped now, but I'll do this if it starts again..cheers. Quote Share this post Link to post Share on other sites
