skidz 197 Report post Posted November 25, 2010 So, have reassembled my E30 Baur, 325 etc and the speedo has stopped working. have tried different clusters, fuse, checked the plug at the diff. Any ideas? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted November 25, 2010 Is it the speed reading that has stopped working (the needle), or the mileage (odometer)? Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted November 26, 2010 Is it the speed reading that has stopped working (the needle), or the mileage (odometer)? Both have stopped, but the other guages work (fuel, temp, lights etc) Quote Share this post Link to post Share on other sites
Guest Si Vis Pacem Report post Posted November 26, 2010 (edited) Both have stopped, but the other guages work (fuel, temp, lights etc)Check the little drive cog inside the speedo mechanism. It's about 4mm in diameter and made out of a rubbery-plastic that gets very brittle with age; I've seen many that have crumbled away in varying degrees. You can carefully prise them off and replace with a good one if need be.Cheers Ken. "have tried different clusters" I missed this, ignore me! Edited November 26, 2010 by Si Vis Pacem Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted November 26, 2010 Check the little drive cog inside the speedo mechanism. It's about 4mm in diameter and made out of a rubbery-plastic that gets very brittle with age; I've seen many that have crumbled away in varying degrees. You can carefully prise them off and replace with a good one if need be. Cheers Ken. "have tried different clusters" I missed this, ignore me! All seems a bit weird, I am wondering if there is an earth wire from the loom to the body I think it attaches near the ecu - I will check tonight Quote Share this post Link to post Share on other sites
Guest Si Vis Pacem Report post Posted November 29, 2010 All seems a bit weird, I am wondering if there is an earth wire from the loom to the body I think it attaches near the ecu - I will check tonightProgress? Did Price pull finger and offer to help? Quote Share this post Link to post Share on other sites
skidz 197 Report post Posted November 30, 2010 Progress? Did Price pull finger and offer to help? No progress, car is off having new exhaust made (last job before warrant check) Mr P may well have offered, even if he doesn't know it yet. Can only be the sender unit at the diff (I have a spare to try) or a broken wire - tried everything else! Quote Share this post Link to post Share on other sites
