swordfish 30 Report post Posted December 21, 2010 Hey guys need E36 M3 3.15 diff or crown wheel and pinion. URGENTLY!!! Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted December 21, 2010 Guessing a bolt did escape then You don't need to get a crown wheel and pinion from an m3. Any medium case will do. You can also change the gearing for a 3.23 or higher if you wanted a little more go Quote Share this post Link to post Share on other sites
swordfish 30 Report post Posted December 21, 2010 Guessing a bolt did escape then You don't need to get a crown wheel and pinion from an m3. Any medium case will do. You can also change the gearing for a 3.23 or higher if you wanted a little more go Yeah shitty little bolts!!! Lol Three of them escaped... Quote Share this post Link to post Share on other sites
moe 31 Report post Posted December 21, 2010 may have something,this should be an 8 bolt diff correct? Quote Share this post Link to post Share on other sites
