m325i
Exhaust Manifold
Exhaust Manifold
325i m20 pre facelift
Or headers if you know of some ???
Cher to the cher
I don't think there's a difference between the facelift and prefaclift motronic engines manifolds although can someone else confirm this.
Got a manifold at home on the wreck.
Its off a 323i but they are the same i think, in good condition.
PM me and make an offer if you are interested.
Guest Andrew
there is - where it bolts to the rest of the exhaust is different.
A 323 manifold won't bolt onto a 325 exhaust, Carl and Andrew are both correct all motronic manifolds are the same, the problem is the release of the motronic system was not at the same time as the facelift. All 323 E30 are L-jet and all 325 E30 are motronic facelift or not
still waiting....
new rears so slightly more unlikely, but not by much
Guest Andrew
Anyone know of one yet?
have you called a wrecker yet - or Brent, Orewa Guy or Rosedale guy?
The guy in Orewa will have one 09 421 0897
The guy in Rosedale - Brett - 479 2060
Try them.
