DrphTa
Problem removing headunit
Tried to put my old headunit in today (Fusion Ipod docking).. before I could even get it out of the box I had trouble getting my original one out. The idiot before me must of had a go and has broken all the clips on the stereo loom/adaptor if you will. The apaptor is actually broken in the back of the headunit. It would not come out with force. I used alot..
Any ideas? Dont really wana start cutting
Will get a picture tonight
you will need to move the slider over for it to push the plug out.
bring it around if you want have done a few like that.
021433600
Cheers Brent, but bringing it around is not an option
I have no slider anyway, it has been broken off.
See picture
Edited by DrphTa
It does look mongralled a bit, as Brent said there should be a slide clip on it to release, if not then it is more than likely broken, better to just cut the plug off and rewire it to the new unit.
ok , just pull real hard then and maybe use a screw dirver as a lever.
10 bucks it's super glued. Knowing previous owners ;)
Cold chisel? haha if you aren't too fussed about damaging the old stereo..
Have tried 3 screwdrivers at once. I think I might be cutting boys!
That's what i did with mine, also ipod docking, just hard wired the headunit plug to vehicle wiring.
I might do this, although I could go and cut an original harness out of a wrecked e36 and wire it back up. So i have the option to put the standard headunit back in. hmm
Decissions, just do it ha.
Does anyone have a wiring diagram for the headunit. I dont seem to have a Remote feed from the car? :S
Have had a look at the pelican website with no help.
White wire is remote turn on, brown earth, red acc power etc etc.
Yea, after I got the diagram is took me 5 minutes lol. Wiring my black e36 in the dark was so much easier haha
Got this for pretty much next to nothing today aswell. Just looking at what it looks like plugged in.
I need another tray below the OBC if anoyone has one?
