Jamie W
M50B25 Loom and ECU
Looking for an M50B25 e34 loom and ECU. Must be vanos. If anyone has one or both for sale please let me know.
Jamie
Edited by Jamie W
you want a e34 type right so it fits a e30 better??
Err, dosent the E36 one fit better?
You need to cut the plastic off it etc, but the wires to the ecu are longer and allow you to run the ecu in the cabin.
Can do loom and ECU
Can do loom and ECU
The e34 ECU sits better and on the right hand side than to the left like with the e36. Also means i wont have to worry about the EWS and all that blah :)
HELLBM how much would you be after for the ecu and loom?
Jamie
Jamie
The E34 harness is not long enough to put the ECU in the cabin and will have to sit in the battery tray. You will need to water proof the ECU somehow.
Once you cut the plastic housings off the e36 loom you can put the ecu on either side.
Jamie
PM`d
Regards Ray
