Garett 103 Report post Posted July 11, 2016 Haha yeah it's a bit out there huh... Is a work in progress It can raise and lower and tilt it's angle, I blew a fuse with my welder, if I could find the darn fuse I'd finish it lol Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted July 11, 2016 Haha yeah it's a bit out there huh... Is a work in progress It can raise and lower and tilt it's angle, I blew a fuse with my welder, if I could find the darn fuse I'd finish it lol The wing is way OTT if you look upon what was used for the mid 90's ST and that wing provided more than enough down force. Unless your intent is running Superlap where wings are designed by ex aero space engineers ( note ex ) then its perfect for FB brownie points but pretty much useless there after. Mind you i like the adjustment part on it Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 11, 2016 You guys wana see the build pics for the wing? 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 11, 2016 The wing is way OTT if you look upon what was used for the mid 90's ST and that wing provided more than enough down force. Unless your intent is running Superlap where wings are designed by ex aero space engineers ( note ex ) then its perfect for FB brownie points but pretty much useless there after. Mind you i like the adjustment part on it Yeah not sure if I'll use it on my race car... Well maybe haha would look totally badass It's my mock up car for ideas, they changing all the time. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 11, 2016 Work in progress, not the final ideal but I'll get there Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted July 11, 2016 you can get those body kits already Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 11, 2016 you can get those body kits already Where abouts? Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted July 11, 2016 If you search for 'e36 fender flare guards' you'll find them. Apparently it's a thing now. And TBH I used to hate sh*t like this but nowadays I'm starting to appreciate the time, effort and ingenuity, even if not the aesthetic. So, I initially thought "yuck" but now I think "go for it" and am looking forward to seeing what you can engineer. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted July 11, 2016 Where abouts? A good friend of mine Jon Sowden owns Strange Workshop he has a agency for them Pandom is the brand from mem https://www.facebook.com/StrangeWorkshop/?fref=ts Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted July 11, 2016 https://www.facebook.com/StrangeWorkshop/photos/pcb.1144940005539766/1144938898873210/?type=3&theater Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 11, 2016 Those kits are awesome but at 6k i think I'll pass, try make something myself. 2 Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted July 11, 2016 Those kits are awesome but at 6k i think I'll pass, try make something myself. Fair enough too and use to do the same, till i sat down and worked the hours it took to do something and time lost when it could have happened quicker. I try to work smarter not harder, but there's still satisfaction and doing it yourself Quote Share this post Link to post Share on other sites
Daniel0663 30 Report post Posted July 11, 2016 Awesome stuff Garett. I kind of liked the idea of the audi all road flares but the new pandem style kits are ace as well! looking forward to the next update. You guys wana see the build pics for the wing? Yes please hahaah Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 11, 2016 Started with a old wing core I had lying around, was determined not to spend any money on this wing and just to use what was around, got some front sway bar links off a e90 and front bumper to chassis support mounts that are usually welded to the chassis rails, also off e90 for the base of the stands, some alloy sheet I used for my floor that I had left over to build where I'm upto now, had to use some e30 handbrake cables to support the left and right sway of the wing which are also adjustable. Still to do on the wing is getting an Audi 80 rear wing and cut down to size and place between the two stands attached to the boot and have it adjustable as well for a twin wing look. Then go through and clean up all the edges, bead blast and anodise the alloy, sand and paint the cores and make the wing blades for the side. I toyed with all the ideas of using seat rail motors to make it adjustable from the cabin area which would have been fun but lack of time stopped this, might revisit this one day 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 11, 2016 You know what's cool, tyre letters on race cars ?? 1 Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted July 11, 2016 Felony form or fitment lab over fenders might be the way to go, will give you 50mm rear and 30mm at the front. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 11, 2016 Loving the DIY bro Quote Share this post Link to post Share on other sites
richard 384 Report post Posted July 12, 2016 (edited) nice progress, I've been in touch with the guys at felony form. I'm placing an order next month. Edited July 12, 2016 by rich 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 12, 2016 What's the costing a on that? I had some wheels arrive today one set of 17x8.5 et35 for use in the wet and a set of 17x9.5 et35 for use in the dry turns out with this offset I don't think I'll need to run any flares now, may just space the front guards out 5mm by slotting the holes that way can run the 9.5's up front with the 265/625/17 slicks 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 12, 2016 The tyre on the car now are 255/40/17 so when the slicks go on they should be lower profile and wider Quote Share this post Link to post Share on other sites
richard 384 Report post Posted July 12, 2016 About $700 US plus shipping. (they quoted $700 shipping cost but I can get it cheaper). Go have a look at their web site. They have a good write up on "stance works" as well. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 12, 2016 About $700 US plus shipping. (they quoted $700 shipping cost but I can get it cheaper). Go have a look at their web site. They have a good write up on "stance works" as well. That's a bit more within reach than the pandom one Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted July 12, 2016 You don't want a alroad kit do ya?? I could make it fit nice I reckon hehe Quote Share this post Link to post Share on other sites
richard 384 Report post Posted July 12, 2016 Na M8 wrong colour. but thanks anyway. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 8, 2016 (edited) A couple of updates, just ordered in some 86.5 mm forged Pistons, con rods and arp studs for a s50 engine that I had tucked away in my one day I'll do something with you pile. Don't know if I mentioned earlier in the thread that I acquired a s50b30 engine from a e36 in which I took the gearbox, subframe, Diff, axles, brakes etc from. It had broken a valve and was bouncing around in the #6 cylinder which caused some pretty serious damage, was thinking of trying to repair it when a s50b32 cylinder head came up on trade me and I picked it up at a good price, I thought the ports on the m50b25 even with being ported were big ports it had nothing on the s50b30 and the b32 are even bigger!! ive stripped and cleaned back the whole engine ready for the rebuild, while the engine is out the body will be getting the once over, gearbox overhaul, driveshaft and clutch upgrade as I'm not sure the factory updated clutch will be up to the job. ive been trying to find someone in Nz who has turbo the s50 with very minimal luck, has anyone done it with forged low comp pistons here? Edited November 2, 2016 by Garett 1 Quote Share this post Link to post Share on other sites
