Garett
GDM - E36 Drift/Race Project
After looking over the specs and doing some reading im going to stay with the b32 cams as they should be fine for my build and are already mated to the lifters and shims
Ive just been going through the BMW catalogue and getting part numbers of what i think i may need..
My Orders List:
Engine Block:
11111317548 x 1 Nozzle mesh gause top of block
11121726243 x 2 Dowel 13.5mm
11121726238 x 8 Dowel 10.5mm
11111743118 x 2 Dowel 14.5mm
11111403958 x 1 Maybe Chain guide Bearing bolt
11421317278 x 1 Oil spray nozzle under piston
Under Intake:
13411401660 x 1 Idle Control Valve lower hose
13411403013 x 1 Idle Control Valve Upper hose
13901403010 x 1 Idle Control Valve Upper hose to rear top rail steel pipe
Timing:
11311405081 x1 S50B32 Chain Tensioner
11311317335 x 1 RH Upper Chain Guide rail
11311309945 x 1 RH Lower Chain Guide rail
11311317339 x 1 Top Chain Guide rail
11311317338 x 1 LH Chain Guide
11311317668 x 1 Chain Guide bearing bolt
11311403081 x 1 Timing Chain
11311317332 x 1 Idler Sprocket with needle bearing
Vanos Delete:
11311403367 x 1 Exhaust Sprocket
11361401494 x 1 Exhaust Sprocket locker
07129905536 x 6 Exhaust Sprocket bolts M6x16 8.8
Engine Sump:
11411401399 x 1 Oil Pump Chain
11411317650 x 1 Oil Pump Chain Tensioner
11417838123 x 1 Oil Pump - S50B32 Duel Pickup
11411404621 x 1 Suction Pipe
11411404635 x 1 Suction Pipe o-ring 20x2.5
11411404584 x 1 Return pipe
11361404409 x 1 Return pipe o-ring 12x2
11411404645 x 2 Support Brackets
07119904524 x 2 Support Bolts M6x16 8.8
Cooling System:
11531318274 x 1 Thermostat
11511405720 x 1 Water Pump - Exchange # 11511406650
11531402571 x 1 Steel Coolant pipe under intake
11531318404 x 1 Connector to Steel pipe
11121318054 x 1 Maybe - Regulating valve on cylinder head by vanos??
Mountings:
22316799331 x 2 Gearbox mounts
11812283798 x 2 Engine Mounts
11611437560 x 1 Rubber cap for throttle body
The quantities are not relative to the engine just numbers of parts i personally require
Edited by Garett
Update: S50B30 engine crankshaft has been polished and rotating assy is getting ready for balancing :D:D, All bearings are within spec too, i was a little worried about this one, didn't really want to go ordering oversize bearings...
Edited by Garett
Are you not going to do an oil separator delete and use a catch can instead?
I would have thought with such a high powered boosted engine that removing it would make sense?
Correct me if I'm wrong.
sh*t yes your dead right... will remove that from my list ;) cheers
  • Like 1
What cooling will you be using for the engine?
what's the cost of the engine rebuild if you don't mind me asking
Nah no worries when I know total figures and for what for I'll let ya know :)
At the moment as you guys may know already I'm running a very basic Fenix alloy radiator, running a Mini Cooper puller fan, remote bottle and viscous fan removal
What I'd like to do it upgrade the radiator to a thick core mishimoto type.
Pretty standard cooling system at this stage
Thicker radiators don't improve cooling they mask issues
I don't think I'll have any issues with the set up I have now but time will tell... ?
In what way? increasing power output will increase heat output, so generally a bigger radiator will be needed.
though ive generally found bmw radiators to be quite big and good from the factory.
  • Like 1
Do a google to understand how performance cooling systems work
  • Like 1
Hey Crunchy, can u give a quick overview of what cooling you would recommend?
I'm building a e46 with a m62b44 and would love some advice on the subject of cooling.
Thanks mate
  • Like 1
What do you guys think of this http://www.dragzine.com/tech-stories/ignition-electronics-efi/wideband-airfuel-ratios-from-every-cylinder-with-aem-electonics/
im may of touched on this earlier in the thread...
Not sure i could be bothered with that many o2 sensors. if it was me and inclined that way would prob go single o2 sensor and individual egt's. but thats just me.
Hot water comes out of engine, and with any luck cool(er) water goes back in?
  • Like 2
I've always wanted to have each cylinder tuned, I have access to muiltiple wideband sensors, but I find myself wondering how I'm going to read all 6 and link them into the link G4 ecu, I should have enough free ports but understand there may be a controller that may be needed
Edited by Garett
I've also got access to muiltiple egts, but how do I set up a way to read them, should I plug them straight to the ECU
Depends how many analog inputs your ecu has. that aem controller outputs each afr signal as a 0-5v analog. so you'll need at least 6 analog inputs for that. and then for the thermocouples, if your ecu cannot take them directly  (unlikely ) youll need an amplifier and another 6 analog inputs for the egts.
Link g4 extreme has 11 analog inputs and im not sure if that's incl your tps, map, coolant and air temp sensors. if you incl oil pressure and temperature, fuel pressure etc you start eating up your analog inputs pretty quick.
Edited by polley
  • Like 1
Egts sound like the cheapest option if they will directly work..
In light of that then you dont need my input
Ok answer this, what are you going to do with all this data and how are you going to make use of it ?
I did a 80k twin turbo big block the other week, once tuned correctly we only monitor 02 readings per bank even then the owner has no idea what to do with the data. ( Cant hold his hand even time he uses it )
Just have it tuned right to start with using the intended fuel, there is no such thing as a "safe" tune however a tune is either right or wrong end of story.
if you think you have time to watch a bunch of gauges when pedaling this thing then your streets ahead of anyone else i know, set within the ecu the limits and setup warning alarms for main parameters then drive the thing as intended.
Monitoring EGT's per pot is a cool thing if you were after the absolute hp even then its questionable to whether its needed, plus EGT's chill off quickly once throttle is closed and slow to respond.
Like i said tune it right to start with, no Knock and dont set it on the edge, go forth enjoy it as intended.
I would cover the cooling thing but that seems to be covered above.
  • Like 1
I would be interested to hear what you recommend.
No I'm actually interested in what you have to say, as I have been through this with my own car and ended going back to a factory radiator and its fine. The only reason I originally "upgraded" it to a fenix radiator was because the power steering pump munched the old one. The fenix one was rubbish...
I would google it, but as you know, the results can be misleading.
