_BRS_ 209 Report post Posted October 8, 2018 I got mine through these guys, http://www.fortyone.co.nz/parts/show/2936/Mishimoto/Performance Radiator.html# Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 24, 2018 Cheers guys, been pretty sh*t with the updates and now im getting things back on track, whats happened in the past year since i had the engine dynoed, ive always had an issue with a vibration at 3k that would rattle my teeth, it was pretty bad, i spent countless hours looking over every thing and came to the conclusion it was an imbalance in the engine possibly from incorrect balancing, so i teared down the engine and sent it back to the engine re-conditioners to get checked and they found it was way out, they were real good about it and covered the cost of new bearings rings gaskets etc to rebuild it, i've just finished putting it all back together and is going in to get dyno tuned on Wednesday, the first dyno i had the valves set so there was about .75mm of overlap and the power dropped off at high rpm so ive set them at around 3mm of overlap to see if the power range would move up... Right now the engine has a lumpy idle, im guessing its due to the overlap and a bit of revision but as soon you give it a bit of gas it is super smooth and little to no vibrations at all Other things added is a fast response IAT and auxiliary water pump to the turbo and waste-gate coolant lines to make sure the coolant flows in the right direction 5 Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 28, 2018 Good to hear that the balancers forked out a little. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted December 3, 2018 (edited) So been learning heaps... right now its putting out 520hp at the wheels at 18psi boost and the torque is awesome so going to run like this for a bit then re tune with different cam set up in a years time seen is that is is Christmas and there's presents to buy, right now as it is feels so much faster than my last engine, in forth gear cruizing at 100kph then floor it it spins the tyres which is fine for now... fastest car ive ever driven... Early in the new year its going to get a tidy up and made road legal Edited October 6, 2022 by Garett 5 Quote Share this post Link to post Share on other sites
BatMansWilly 74 Report post Posted December 6, 2018 Glad its finally running right and making good power and you are able to drive it must feel great! I think we need to see a few videos of the old girl hooning hahah ? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted December 6, 2018 (edited) Well done Garett. It's been a long journey ? Edited December 6, 2018 by B.M.W Ltd Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted December 7, 2018 Really ? adding overlap will limit high rpm power gain Quote Share this post Link to post Share on other sites
