jeffbebe 1587 Report post Posted May 21, 2012 Awesome. I'd be happy with half your motivation and 10% of your know how! I'll have to settle for beg, borrow and stealing (well, working, in my case) to pay for the work on my car! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 22, 2012 The setup is still a work in progress. But it works. The biggest gains were between 2000 and 3000 where the power is up by over 60% The AFR is a bit rich We stopping working on it after the fan stopped and she got a bit hot. I think I will fit an inter cooler and tidy up some of the pumping before I have another go at tuning it. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted May 22, 2012 The car went on the dyno after work today. Standard atw 95hp (70kws) supercharged @7psi 135hp (98kw) While it doesn't sound like much its still a 40% increase Had to change the injectors, stole some from a 90's rvr I like!!! And what about the torque..... Guessing up by a fair whack if you're seeing +60% power through the midrange. Are you going to try one of the cheapie W2A intercoolers from Tardme between the SC & Inlet? Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 22, 2012 I like!!! And what about the torque..... Guessing up by a fair whack if you're seeing +60% power through the midrange. Are you going to try one of the cheapie W2A intercoolers from Tardme between the SC & Inlet? have you got a link to them? Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted May 22, 2012 (edited) have you got a link to them? There were heaps on TradeMe not that long ago.... found this one plus this just need to add a pump and some controls Edited May 22, 2012 by E30-323ti Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted May 23, 2012 Hey Eddie I got a intercooler at home off a 09 ra rodeo. If you want it let me know. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 16, 2012 (edited) Thanks but I fitted an inter-cooler off a vr4 The bonnet has also been fixed and painted along will the bumper also a bit of CF with some cheap gauges mounted it Edited June 16, 2012 by rot62 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 16, 2012 (edited) I been thinking about long term engine options. At first I thought about putting in a 2.8l, but really this car was always about letting the kids having a go at motorsport. (plus I could use it) so I think a 2.8 is a bit to much for a 12year to learn in. A 6cylinder also means it will need bigger brakes straight away. So I'm back to keeping with using a 4pot for the time being. As the supercharger was only a raining day project done with limited funds (less than $200 to do) I never intended it to be used once the car has a roll cage. So we have pulled down a M44 a mate gave me I'm going to use SR20de pistons, with 1.4mm machined off the tops this should give the engine a CR of 12.5:1 If I bore it out from 85 to 86mm I can use an M44 head gasket, I would like to go to 87mm but not this engine at this time M44 rod with sr20 piston fitted Edited June 16, 2012 by rot62 Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted June 16, 2012 (edited) Ah jeees Ive just bought a set of DE (low comp) and DET pistons as well. Thought i might have been on to somthing there. Turns out im 5 min late again. Will be watching to see how this goes together. I take the need to machine 1.4mm off is because your using a M44 crank? M42 and DE compression height are very close to oneanother so if a m42 crank is used then machining wouldnt be needed? or at least to a lesser degree. Also valve pockets will need machining? Edited June 17, 2012 by MLM Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 18, 2012 If you use the M42 Crank you don't need to machine. The Low comp de pistons will give you about same CR as a standard m42, the det will be lower again. I'm going to use the flat top de pistons, I still might only machine 1-1.2mm off and have them come up out of the bores to allow a little more for the machining of valves and head work, and still ended up around 12.5:1 CR Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted June 18, 2012 If you use the M42 Crank you don't need to machine. The Low comp de pistons will give you about same CR as a standard m42, the det will be lower again. I'm going to use the flat top de pistons, I still might only machine 1-1.2mm off and have them come up out of the bores to allow a little more for the machining of valves and head work, and still ended up around 12.5:1 CR you can also use m50 135mm rods and mitsi evo pistons works good for forced induction Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 18, 2012 if you get the early evo pistons' the valve pockets will even be the wright way round Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted June 19, 2012 I took the car for a drive to Tauranga on Monday. I only got about 20km's out of Rotorua before the fuel pump plug on the fuel tank burnt out. I dodgy that up and continued on my way. About another 10-15kms and the car started to lose power, then after a little while it came back and then looses it again. It turns out the rear muffler is blocking up. Time to replace it. $101 dollars at repco gets me a new 2.5" muffler and now the car rev's out The old peace of sh*t I have also install some new white line front castor bushes Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 16, 2012 A bit of an update. Not to much progress Took the car for a wof, Failed on drivers seat belt , rear seat belt, no horn button, no door panels and strangely enough the supercharger. Seat belts fixed, horn works, door panels are getting made out of fiberglass, and I'm going to unbolt the supercharger to get a wof. Some XYZ suspension has been ordered, And a friend at BNT is going to sort me out some better brake pads. I have made some panels for behind the bumper to help duct the air into the radiator a little better, as the car had nothing at all Mounted a isolating switch, starter button, and some extra switches to help control the extra power Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 16, 2012 I think you forgot some decimal places when you printed your labels Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 16, 2012 I was thinking I could be missing some zero's Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 19, 2012 diff and subframe out Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted July 19, 2012 diff and subframe out Are the rear subframe bush holes larger then the front Eddie? I noticed them on my m3 bushes last week when I was installing them. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 20, 2012 yes Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 27, 2012 I have made some reinforcement plates and welded them in Installed a fire extinguisher and some door panels Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted July 27, 2012 Brought a smaller battery battery mounted Also I removed the supercharger to get the car wof and reg today Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted August 1, 2012 Some new bits turned up today so they got installed tonight 8kg front 7kg rear Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted August 1, 2012 I think its a bit low for my liking, may have to lift it up a little Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted September 7, 2012 I hate wires Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted September 7, 2012 I hate wires What might you be upto Eddie? Quote Share this post Link to post Share on other sites
