NZ300E
WTB e30 foggy switch + relay
WTB e30 fog light switch...you know,the one beside the headlight switch that fits in the blank...Plus the relay for fogs.cheers
Edited by NZ300E
I think I have a fog light switch somewhere in the garage, I will have a rummage for you.
Do you know the part number for the relay - i have a box of them, so should have the right one somewhere!
dual switch or single switch?
let me know if you have no luck
[email protected]
Cheers let me know how you get on.
Bump
can do
I have found the switch - the two button one, one for fronts, one for rears.
Did you manage to find any info. on the relay? I have got a relay that has the right connections, just not sure where it goes in the car and whether the terminals fit Ok.
^^^^^^ All the main fuse box relays are the same configuration Jon
After much sorting through boxes the end result is that I have the swith, but no relay that fits in the fuse box. PM me if you are still interested in the switch.
