dubman 39 Report post Posted September 17, 2011 (edited) During a thread dig, Alias and Cliffdunedin mentioned a subaru upper engine cleaner, after googling this product also, decided to give it a go. Boy does it make a difference. It returns to idle smoother, the engine breathes easier and little vacuum leak symptoms dramatically lessened. The most noticeable thing was 1st gear, the car no longer jerks and stammer, just smoothly idles along, and the throttle response is alot better (without load). Made all this difference AFTER i cleaned my intake and throttle body thoroughly. Highly recommended !! Edited September 17, 2011 by dubman Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted September 17, 2011 Is that the same as "Sea Foam" Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted September 17, 2011 (edited) very similar product iirc. cheaper and easier to source, Repco didnt stock seafoam or have it as an item Edited September 17, 2011 by dubman Quote Share this post Link to post Share on other sites
slowe30 0 Report post Posted September 17, 2011 it worked great on my e30. cleaned so much crap out the idle rose from 700 ish revs to over 2000. also i work on subarus and use it on every service i do. just try not to breath it in, its cancerous Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 18, 2011 Don't use on cars with o2 sensors unless you're going to remove them before doing this. regular oil changes are the key Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted September 18, 2011 Glad to hear it worked well on your Bimmer! From my experience has worked magic on Subarus and Mitsibishis. Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted September 18, 2011 Don't use on cars with o2 sensors unless you're going to remove them before doing this. regular oil changes are the key Subarus have O2 sensors.... Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted September 18, 2011 was thinking of doing it but damn.. so much smoke comes out. anyone got an idea how to "mask" it? like funnel exhaust under water or something? LOL Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted September 18, 2011 i went to an industrial parking lot. attempted to do a burnout or two afterwards. but only tyre squeel Quote Share this post Link to post Share on other sites
