Beeker2 70 Report post Posted November 3, 2011 I have 3x leaking power steering hoses on the E46 M3. BMW have quoted $1k alone for the parts. Is there a good source locally for alternative parts that are still quality, or internationally for OEM? Or do i just sux it up? Just seems like allotfor 3x pipes! Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 3, 2011 1k seems a bit steep. Might be best to order from overseas. If you haven't seen this yet it might be worth a look http://realoem.com/bmw/showparts.do?model=...;fg=20&hl=6 I've found that realoem prices seem to be about what they cost from US sellers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 3, 2011 1k seems a bit steep. Might be best to order from overseas. If you haven't seen this yet it might be worth a look http://realoem.com/bmw/showparts.do?model=...;fg=20&hl=6 I've found that realoem prices seem to be about what they cost from US sellers Careful buying steering components overseas. They may be LH drive Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted November 3, 2011 Just hoses? Would seem hard to believe that Enzed Hoses(?)/Hydraulink or someone similar can't make up at least OEM spec or better hoses for less than $330 a piece. Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted November 7, 2011 Just hoses? Would seem hard to believe that Enzed Hoses(?)/Hydraulink or someone similar can't make up at least OEM spec or better hoses for less than $330 a piece.This is a good suggestion that I have used myself. I have had Enzed make up hoses. They have sometimes used the original hose end fittings and welded them to suitable fittings to crimp onto their hose. The replacements hoses have been cheap and effective. Quote Share this post Link to post Share on other sites
