Palazzo 522 Report post Posted November 8, 2011 I have a leaking clutch cylinder (I presume), how do I tell which? I remember one used to leak in the drivers footwell, no leak this time. Need to know which one to order off Gavin, or should I just do both again? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 8, 2011 master is inside , slave is outside on the box Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 8, 2011 Remove the slave cylinder from the gearbox and check if fluid has filled the boot and is leaking into the bell housing. Remove the under dash panel and check the master in the same boot area for leaks. Have you tried bleeding it ? BTW....never presume Quote Share this post Link to post Share on other sites
jcerecke 2 Report post Posted November 25, 2011 One of my cylinder's is leaking too, got AA in and he put some more fluid in and bleed the slave to just get me home. I was just about to assume that it was the slave, but I might not anymore (thanks glenn) haha. Quote Share this post Link to post Share on other sites
