330iMSport 0 Report post Posted November 16, 2011 Hi team I've got a E46 330i due for new pads and rotors on the front. Priced up genuine BMW and if you're interested: Pair of pads $253 + GST Wear sensor $62 + GST (for the pair I assume) Rotor $328 + GST each Can anyone recommend any non OEM options that will hold up well and be a cheaper? Not any area I particularly want to skimp on but no doubt there is a "BMW" premium built into OEM, that I'd be happy to avoid. Thanks in advance Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 16, 2011 Price with the obvious - Repco, BNT etc, Euro Italian on here. BMW rotors are inherently soft anyway so wear factor of aftermarket will probably be similar to OEM Quote Share this post Link to post Share on other sites
330iMSport 0 Report post Posted November 16, 2011 Thanks for that. You hear the odd horror story with cheap and nasty rotors so wondering if there were any in particular to avoid. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 16, 2011 mmm... hard to know. A few years ago I put some Ching Fung Dung or whatevers on the front of the E39. Partly/ mainly because of cost (about $50 each compared to about $175+ ea OEM), but also with the theory that they couldn't be worse than the 65k that the originals lasted on the car. I did fit OEM pads though - much cheaper than you quote Famous last words though... they developed a severe shudder after about 25k so had to have them skimmed about 12 months ago. They have been ok since, car now at just over 100k Sooo in effect - milage will probably be as good as OEM Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted November 16, 2011 I highly recommend the Mintex pads from BNT. I have used these on various BMWs including a 330ci. They have excellent performance, and never squeak. The only downside would be higher disc wear due to the coarseness of the pad, but given the massive price difference, I wouldn't be too worried. With regards to rotors, I get Brembos from BNT - they're cheaper than factory and also provide excellent performance. PM me if you require any more details. Cheers, Andrew Quote Share this post Link to post Share on other sites
EVILRE30 0 Report post Posted November 17, 2011 I recommend Bendix Ultimate's pads matched with Brembo rotors from any BNT.You could also go to Racebrakes in Kingsland Auckland and run EBC Greens great for the street they have a down side to them being a bit noisy when cold but great bite for street use.A bit more harsher on your rotors then the Bendix Ultimate's as for rotors i could only recommend Brembo's as the other option at BNT was Chinese rotors no offense to any one but i wouldn't run them on any cars i own.Hope that helps price wise you would save a lot but i would see what other members have to say. Quote Share this post Link to post Share on other sites
330iMSport 0 Report post Posted November 17, 2011 Thanks all. Gives me a few options to price up Quote Share this post Link to post Share on other sites
dreadful1 7 Report post Posted November 17, 2011 this all sounds like good info for me when I need to change brakes, where is this BNT you speak of? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 17, 2011 (edited) I've got this Edited November 17, 2011 by bbs Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 18, 2011 this all sounds like good info for me when I need to change brakes, where is this BNT you speak of? BNT - all around the place. Look in your phone book:- Quote Share this post Link to post Share on other sites
