oscar90 0 Report post Posted November 27, 2011 Hey Guys, just brought a cheap S.A. 325i with afew broken Rocker arms, Who's replaced some and have you done it Head on? I've read your ment to do it with the head off, but it's quite possible to do it with head on so it seems, just more of a pain in the ass, so would like to try it head on since it was dirt cheap! don't mind if it takes me abit longer Also who's brought rocker arms locally and how much?? pelican parts work out at about $25 ea, don't think i'll get much cheaper than that Andrew Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 27, 2011 It'd be a lot more fiddly to do with the head on, more chance of breaking/damaging something else too. I'd replace all the rockers if you're keeping the car. Pelican is best Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 27, 2011 (edited) Broken rocker arms probably = broken cambelt & bent valves as well... which would = cheap Edited November 27, 2011 by *Glenn* Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted November 27, 2011 They do just break on their own dont they??? Anyway that was gonna be the next question!, cambelt was done approx 2000kms ago, If it's out of time it'd more than likely cause them to break wouldn't it? Just weighing up the options, if it's cheap enough to fix i'll do so and drive it around, if not might pull all the goodies off and get rid of it to the scrap yard/wrecker. If the body was in better condition id put the M50 and that'd fix the M20 for good haha Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted November 27, 2011 Assuming the heads ok ( hasnt been overheated) why not take it off,get it checked,replace rockers yourself,new gasket & bolts=$500 maybe & u have a good engine. Quote Share this post Link to post Share on other sites
melowpuf 19 Report post Posted November 27, 2011 It is possible to remove the rocker shaft in situ on an E34 m20.. carefully.. I have done this with a couple of engines.. not sure how much more you would have to remove on an E30. From memory I raised the engine a bit for clearance over the front so I could get it out far enough to remove/replace the broken rocker. No idea why they broke, wasn't timing or cambelt.. they just gave way.. replaced them and off I went again. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted December 6, 2011 We removed the engine, for the hassle / fiddling round in the engine bay it was actually quicker to get the engine out, in open space and do it there. Word of caution if you are doing it your self, when hitting the shafts to get it out, be careful as not to dent a hole in the middle, as oil goes through there. So choose your "hitting rod" carefully, im not sure how others do it but im assuming a rubber cover will save some damage. Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted December 6, 2011 Have managed to change them in the engine bay,hassle tho, if you want some rockers just to get the thing running let know,cheers jon Quote Share this post Link to post Share on other sites
