Antallica 24 Report post Posted January 21, 2012 Hey all, In the last couple of months my outside driver door handle won't open the door, I have to apply pressure to the top corner of the door then pull. It'll open from the inside reasonably well. I've sprayed WD all over the mechanisms and pulled the door cover off and had a look around. Made it a bit worse after all the lol. Anyway does anyone know what's going on? I'm tired of looking like a d*ck trying to open it every day Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 21, 2012 the ali parts inside break so you will need a new handle mech. i have some if needed 021433600 Quote Share this post Link to post Share on other sites
rusteee 52 Report post Posted January 22, 2012 Hey all, In the last couple of months my outside driver door handle won't open the door, I have to apply pressure to the top corner of the door then pull. It'll open from the inside reasonably well. I've sprayed WD all over the mechanisms and pulled the door cover off and had a look around. Made it a bit worse after all the lol. Anyway does anyone know what's going on? I'm tired of looking like a d*ck trying to open it every day Don't know if you've sorted it yet, but I had this issue with mine, very frustrating , had to apply pressure in the top corner to open both the drivers and passengers door. I sprayed some CRC into the actual latching part of the door, on the side (not the door handles) and manually clicked the latch up without closing the door, then released using the door handle a few times, spraying the moving parts each time. This sorted the issue with both doors on mine, and the olds car with the same issue. Shame I didn't try before going out and buying new latches first if you havn;t alrerady tried, hope this helps Quote Share this post Link to post Share on other sites
Antallica 24 Report post Posted January 22, 2012 Don't know if you've sorted it yet, but I had this issue with mine, very frustrating , had to apply pressure in the top corner to open both the drivers and passengers door. I sprayed some CRC into the actual latching part of the door, on the side (not the door handles) and manually clicked the latch up without closing the door, then released using the door handle a few times, spraying the moving parts each time. This sorted the issue with both doors on mine, and the olds car with the same issue. Shame I didn't try before going out and buying new latches first if you havn;t alrerady tried, hope this helps Yeah I did all that, wish it had fixed it. Must be the mechs inside. Quote Share this post Link to post Share on other sites
Antallica 24 Report post Posted January 22, 2012 the ali parts inside break so you will need a new handle mech. i have some if needed 021433600 Cheers mate, will have a think about what I'm gonna do about it. Might just throw it at my mechanic due to my back. Will drop you a line if I need it though. Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted January 23, 2012 don't buy just any e36 door handle from a dismantler, they do differ seen it time and time again , people being sold the wrong handle get the number off the back ie: R1, r2 etc stamped into the handle and lock, cheers Jon ps; any probs just give me a call 04 3801089 Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted January 24, 2012 Hell, this is a common wear issue, both the handles in my coupe are doing this, such a pain in the ass, is it an easy DIY fix or should I give it to someone who knows what they're doing? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 24, 2012 Hell, this is a common wear issue, both the handles in my coupe are doing this, such a pain in the ass, is it an easy DIY fix or should I give it to someone who knows what they're doing? takes a while on the coupes , have to remove the glass etc to get at the back of the handle mech Quote Share this post Link to post Share on other sites
EVILRE30 0 Report post Posted January 24, 2012 Just a bit off topic i have a 95 E36 Sedan i was wondering if i got a pair of rear door handles from the same year and model.Could i replace my front handles so they won't have key locks anymore when i go for a key less entry alarm.Are they a straight fit swap over?any info would be great.. Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 24, 2012 Just a bit off topic i have a 95 E36 Sedan i was wondering if i got a pair of rear door handles from the same year and model.Could i replace my front handles so they won't have key locks anymore when i go for a key less entry alarm.Are they a straight fit swap over?any info would be great..use a front door handle from a late model e36 about 97 onwards they dont have key hole.then use a handle surround from the right rear door to cover the key hole after you remove the barrol from it. and what say your remote fails how would you get in?? Quote Share this post Link to post Share on other sites
EVILRE30 0 Report post Posted January 26, 2012 use a front door handle from a late model e36 about 97 onwards they dont have key hole. then use a handle surround from the right rear door to cover the key hole after you remove the barrol from it. and what say your remote fails how would you get in?? Thanks for that il see if i can find one over here or nz trade me.If the battery dies or the remote fails il call road assistance for the free break in service lol i guess Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2012 Thanks for that il see if i can find one over here or nz trade me.If the battery dies or the remote fails il call road assistance for the free break in service lol i guess Just buy one of these http://www.skygeek.com/ats-32r00-1.html good for breaking windows....ask any car thief Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 26, 2012 Just buy one of these http://www.skygeek.com/ats-32r00-1.html good for breaking windows....ask any car thief Or just a bit of broken porcelain from a spark plug will do it... Smash a spark plug and get a small piece of the porcelain and throw it at the window, will go right through it. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2012 Or just a bit of broken porcelain from a spark plug will do it... Smash a spark plug and get a small piece of the porcelain and throw it at the window, will go right through it. How many times you done it Troy ?? Quote Share this post Link to post Share on other sites
