kwakaturbo 1 Report post Posted January 24, 2012 hi guys ive got a 94 e34 540 ive just had the windsreen replaced and i remove the three computors in the ebox to replace the drivers side wiper spindle,since ive reconnected the computors ive got the trans program message come up and i cant seem to delete it ive gone over my work but i cant work it out and ideas please just a note car was running ok before Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 24, 2012 If the ignition was turned on with the ECU's disconnected it probably has fault codes stored that would need to be cleared with a Scanner Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted January 24, 2012 double check all the conections in the e box , also check you fitted the trans plug into the tcu properly etc. are the relays and fuses ok?? i take it the trans is stuff in 4th gear when you drive?? Quote Share this post Link to post Share on other sites
kwakaturbo 1 Report post Posted January 25, 2012 ive scanned my car again and i get codes for solenoid valve 1 solenoid valve 2 solenoid valve 3 pressure reg 1 pressure reg eds 2 does this mean computor fault ???????????? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 25, 2012 As Brent said... recheck connections, clear fault codes, road test and recheck Quote Share this post Link to post Share on other sites
