DrphTa
S50b32 bigger injectors
Looking to go bigger..
s50's have 'blue top' / 24lb. Where can I get the next step up?
Are 36lb and 42lb too big for N/A?
edit: or 30lb?
Edited by DrphTa
are you maxing out your injectors? or are you planning to do so in the future?
What has your 'tuner' recommended?
As long as the tuner can make them idle, there is no such thing as too big
To add something more helpfull
The s50b32 uses a 5 bar fpr
Injectors are tested at 3 bar. So your injectors should really be flowing about 30lb.
Yea have read that
Cheers.
The new ECU, exhaust and intake may max them out. What hp are 24lb rated to?
Edited by DrphTa
Really? I have a straight pipe intake and exhaust with an Autronic ECU and have never had any fueling issues. Its only ever doing track duty too.
Agree with james, You wont be going anywhere near full duty. Unless you turbo the thing or go extreme cams / vanos delete are running very high RPM. (which you cant really do on the stock pistons/rods)
Wont be needing injectors then!
