BM WORLD
calling all BBS LM experts
got this e36 325i in today
has some 17" by 8" BBS LM's
with a ET40
to me it looks like spoke section should be mounted from the back
is this an option???
but the offset seams to sit right in the e36.
could they be made into a ET20 etc???
Edited by Brent HARTGE535i
You can reverse mount the faces for a different look, will change the offset slightly but not so much that it would make it ET20.
ok thanks as a few of the pictures you see on google show them mounted at the back or are there different versions etc??
what are these things worth???
Ask Josh (hybrid)... he has reverse mount LM's on his 5 stud E30. I believe he just reverse mounted them, didn't have to buy different faces or change anything except bolt them up.
Its as easy as unbolting the faces and the remounting them on the other side of the mounting lip. they are 2 piece so once you get them undone so it will be clear once you take them apart. The offset will only change about 12-13mm.
Guest Ari Gold
As mentioned they can be reverse mounted. Takes them to ET26 iirc, the faces are roughly 14mm thick.
Worth? Whatever someone is willing to pay for them.
